Question about Westinghouse L1975NW Monitor
Monitor will appear to come on a "no signal" sign flashes up then the screen goes black. If you press the on off swich the green light will come on briefly then go to orange and then disappears completely - everything is plugged in properly and the computer works fine with a different moniter- any chance of recovery or is the thing dead???
  • gilliancorri Jun 28, 2009
    Thanks. Appreciate the advice. I think the easiest solution is to buy a new one!!
  • 2,404 Answers
Could be a number of possibilities, lcd backlight is going bad, bad capacitors on the power board, lcd cable needs to be reseated, power board needs to be replaced. Best possibility would be to take it to a repair shop and see what the costs would run to fix it.
If its more then the cost of a new monitor then get a new monitor cause you would get the warranty.
Posted on Jun 28, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
No Signal
You have to use the FN key and F5 to change between the LCD screen and the external monitor. It may be F8 also, depending on the laptop model.
Look on the F keys for a little picture of a monitor.
Once you have found it, hold the FN key and tap the F key and it should switch to the external monitor.
Jan 18, 2008 | Liquid Video E15LCD1 15"
StudioWorks 700s Monitor No Signal
Try to connect the monitor to a different desktop/laptop, to see if it works at all.
Try a different monitor on your computer, to see if the video-card in your computer is the problem.
Or, spend $50 to $100 to buy a used 15-inch or 17-inch LCD monitor.
Sep 20, 2007 | Computers & Internet
Flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Aug 27, 2007 | Hyundai L91A 19" LCD Monitor
Westinghouse L1975NW Monitor Logo
246 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
