Question about Dishwashers
Door handle is locked in place and cannot open
  • 40 Answers
Need more information, make and model , type of handle. I've seen a few stuck handles, one of them someone glued shut.
Posted on Jun 28, 2009
My inside door handle will not engage the latch to open from inside the vehicle Have to open the door from the handle on outside.
There is a metal rod that connects the inside handle to the door latch mechanism. It is locked in place by plastic fasteners. One has fallen off the end of the rod. Opening the door panel requires special tools to prevent permanent damage to the panel.
Jan 28, 2016 | 2007 Buick Rendezvous CXL SUV
2000 mitsubishi galant 4 cyl, 4 door. Rear right door had seat belt slammed in the door. Closed it properly and now when trying to open door from inside latch it won't pull the lever to unlock and open it....
pull the door panel off and inspect the door latch. Sounds like you jammed or bent part of it out of place. If the handles are very loose, check and see it the door latch arm popped out of place
Nov 10, 2013 | Cars & Trucks
How do you fix the door handel when it wont open from the ouside
the outer handle is connected to the lock with a steel rod. If the outer handle has broken or the clip that holds the rod onto that handle has broken, then thats what you need to replace. You will need to remove the inside door trim to access the locks and rods. Remove the door trim as best you can if you are unable to open the door at all and reach into the door to access the inner door lock rod. Pulling or pushing the rod should allow you to open the door and remove the trim completely.
If there is no obvious damage to the outer door lock, check where the outer door handle rod connects to the lock itself as the clips holding the rods in place can fail. If the clips have failed, replace them with new clips from the vehicle manufacturer..
Mar 10, 2011 | 1992 Buick Regal
How do I fix the door/lock of my 1991 Acura Integra? I can only open the driver side door from the outside
There are only 2 places that you have the problem on the inside door handle. one is at the handle,and the little plastic holder that holds the rod to the handle broke, or the plastic clip the the door lock mechanism broke. the first can be removed without taking the door apart. the inside door handle has a screw holding it in place. you can remove the handle and see if its broken. the second requires you to remove the door panel, to replace the clip that hold the rod to the lock. I door handle in the car is a dealer item only(sorry to tell you that), the clip for the lock, you can get at the auto parts store. hope this helps
Jan 11, 2011 | 1991 Acura Integra Hatchback
I have a 93 lexus es300. the door opens from the inside but will not open from the outside. Can you explain or send me a diagram of how the handle operates. the handle appears to be o.k. and the lock is...
There's a short rod held in place with plastic fasteners that goes from the outside handle to the door latch. You need to take off the door panel upholstery panel to get to it. Sometimes you get lucky and only need to put it back in place. If the plastic part is missing, look if it's in the bottom of the door. It's a small piece, but is a dealer item. A automotive glass shop might have them but not likely.
Aug 08, 2017 | 1993 Lexus Es 300
2003 for focus doors wont open outside handle feels loose and wiil not open latch
plastic door handles on this model break easy, buy on ebay or similar cheap places, dealer could be fair also, you need to remove the door handle from inside with 10mm nuts / screws, you need to remove the door panel, google instrucitions, once door panel is off it is simple, make sure you do not disconnect the switch connected to the door lock cylinder otherwise the car will not restart if so equipped, switch turns off factory immobilizer if equipped...make sure you connect the rod to the door handle and make sure you lock the clip on it before you reinstall door panel, test first....
Jul 13, 2010 | 2003 Ford Focus
The inside and outside door handles will not work on my wifes 1999 honda accord. The lock works but i cannot get the door to open. it feels like the handle isnt catching on anything.
latches are siezed and will require so help to open. try using a rubber mallet and tapping the outside door handle till it seems to have some resistance. you might have to tap alot. once the latch spring is in the right place then lock and unlock car to activate the clips and then pull handle. repeat untill door opens, then take door apart, remove latch and oil till all clips and spring move freely. Now put it all back together and it should work well.
Sep 05, 2009 | 1992 Honda Accord
Need to know how to install exterior door handles
I'm assuming that you have the coupe not convertible since I've had same problem with my 97 Dodge Avenger and this is quite common from what I have heard. The handle is held in place by two 10mm bolts. One is easily accessable, located right beside the handle with the door open. The other is a little harder to get at. The first thing you need to do is remove the inside door cover, held in place by four screws and push in clips along the bottom that pull out easily. Two of the screws are visible and in the top corners of the door panel. One screw is located behind the inside handle and once removed the moulding comes off quite easily. The other screw is in the hand hold where you pull the door closed and has a small plastic cover over it. If you have power windows you are able to disconnect the switches once the panel is off. If manual windows, the handles are usually held on by a clip that can be pushed off with a screw driver allowing you to pull of the crank handle. The window needs to be in the closed position so you can access the ONE 10mm bolt holding the outer door handle. Once the interior door panel is off, if any clips remain in the door, take them out and put them where they should be in the door cover it won't go back together properly if you don't. Now you'll need to pull down the corner of the plastic covering the door, don't remove all the plastic just enough to allow access to the bolt. I used a small rachet to get it out. It is in a stupid spot with not much room but is doable. Once out, the handle is only being held by the lock rods to the handle and lock cylinder. The lock cylinder is held by a retaining clip which can be slid off allowing the cylinder to be pushed out. The other rod connected to the handle has a plastic clip on it holding it in place. This can be opened with a small screwdriver. Once opened the rod will come out easily and the handle should come off the door. The only problem reinstalling, that I had, was reconnecting the rod to the handle and found that if you unscrew the door latch, the whole mechanism can be moved down, giving you more freedom to work with the rod. You might want to do this before fighting with the clip holding the rod in place, just a thought as I got mine apart in 20 min. Installing the new handle is quite easy, just attach rod to the handle FIRST before anything else. Once the handle is back on the door the lock cylinder can be pushed back in, it just gets in the way if you put it in the handle right away. Hope this is of some help.
Oct 05, 2008 | 1997 Chrysler Sebring
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
