Question about HP Compaq nx6310 Notebook
How do i connect it to the net? Do i still require an external modem for my broadband connection?
    Sergeant:
  • 280 Answers
Every broadband connection requires an external modem. Your laptop might be shipped with an internal modem. But that is for dialup purposes. Today broadband uses a technology called ADSL. So you require a modem to decode the signals.
Posted on Jun 28, 2009
Acer5536 laptop will not connect to the internet wireless will connect by ethernet cable why
you might have a modem with an ethernet connection to connect to the net .
if you have a laptop you can choose a wireless usb broadband modem which can work on a desktop also once you recieve the modem just insert the modem into a usb port and follow the prompts you might need some drivers for the usb broadband modem which can be supplied by the ISP internet provider
hope this helps
Nov 14, 2010 | Acer 91.AB370.001 Network Adapter
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
I had been using dial-up internet and then switched over to broadband internat. Now since I have disconnected the broadband net, I want to use the dial-up modem. However, I am gtg a note that the device...
It's kind of difficult to tell what your exact problem may be, but note that the cable and connections for dial-up and broadband are different.
The dial-up cable is telephone wire connected to its port in an internal modem. Broadband is connected with thicker Ethernet cable connected to a network card.
The ports look similar, but the Ethernet port is a bit larger.
So, you need to connect to the right port/card with the right cable.
When you connect to dial-up, you should hear a beep-beep-beep sound from the modem.
Hope this info helps.
Sep 21, 2009 | Computers & Internet
I have a Dynamode wireless router which i have configured however the cable which came with it does not fit into telephone connection. What other cable do i require
The nework cable that came with the wireless router has RJ45 connectors (8 wire cable) and the telephone cable has narrower connectors RJ11 (4 wire cable) or RJ12 (6 wire cable - less commonly used).
I assume the Dynamode wireless router does not have a built-in modem and therefore needs to be connected to a broadband modem.
If broadband modem is a cable or DSL type, the broadband modem is connected to the Dynamode WAN/Internet socket with a RJ45 LAN cable.
If you have a broadband DSL modem you need a RJ11 phone cable to connect the moden to the phone socket.
Sep 08, 2009 | Computers & Internet
I have an external modem for broadband connection. it connects only via usb i am not able to connect via the phone cable port. what seems to be wrong?
The broadband modem connects to thecomputer using the USB or nework port not the phone cable port.
The network port has 8 wire connectors and whilst they both look similar the network (10baseT) port is wider than the phone port.
You also need to configure or reconfigure the model to let it know which cable you are using to connect the modem to the computer.
Apr 05, 2009 | Acer Aspire 1703SC Notebook
Cant connect thru DSL(LAN)
hey there i am having a problem with my Vista home premium. = false
I cant connect or get my broadband connected to DSL. = true
but everytime i use my fone as a modem i can surf the net. = true
how come i cant do this with the DSL Line?
1. Your DSL line requires a special kind of modem a DSL modem not a phone modem.
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 23, 2008 | Microsoft Windows Vista Home Premium with...
Siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Modem
To access the ports you mean via the control panel.  If it is an internal modem then XP would automatically install it as a hardware providing it is connected to the motherboard.  I detected you saying that you rebuilt the PC.  Have you slotted an internal modem into one of the periferal slots or did it use an external modem.  Did you know you dont need a modem to logon to the net unless your dialing up? But if you use broadband most use an external modem that connects fast ethernet connection.  But I suppose you know this after all you rebuilt the machine.
Oct 10, 2007 | Toshiba Satellite A10-S167 Notebook
Blinking 2nd light - Broadband connection light
Its disconnected ring the ISP or your Parents?
Sep 04, 2007 | 2wire (1000-000057-000) Modem
HP Compaq nx6310 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
