Question about Philips Magnavox 27MS343S 27" TV
The problem I am having is that when I turn on our tv vcr/dvd combo unit, it only wants to stay on for a few seconds and then it shuts off.
  • Philips Master
  • 1,229 Answers
Diod location would be 1614 replce it with nte 552. Also look for r3568 1/8 watt resistor, replace it with a one ohm 1/4 watt resistor. should repair this unit.
Posted on Jun 30, 2009
  • 1,056 Answers
I have fixed one of these combos before. The problem seem to always been the zener diode to regulate power. It developes a leak which would cause increased voltage, and goes into shutdown mode.
Posted on Jun 28, 2009
Tv will not stay on it turns off after a few seconds.
It is in shutdown because of a short in the set OR if a combo unit the player portion (VCR or DVD) may have a jammed or not working mechanism which will shut the unit off instantly as the set tests those each time it is turned on.
Mar 31, 2012 | Akai Televison & Video
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
SRCD227 tv/vcr/dvd won't stay on
QUE CLAVE O TECLAS DEBO OPRIMIR PARA ENTRAR AL SETUD
Sep 06, 2009 | Sylvania SRCD227 27 in. TV/DVD Combo
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
My Tv is turning off by itself
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
TV wont stay on
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 22, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Sep 16, 2006 | Samsung CXD2512 25 in. Combo
Tv shuts off after5 seconds
I,m sorry if not help you, but some those combo system when the Vcr have problem or stuck it shuts down, then you have to fix the Vcr frist. zcheck if the Vcr is ok. Aleixo
Aug 29, 2006 | eVision EC720E 20 in. TV/VCR/DVD Combo
Philips Magnavox 27MS343S 27" TV Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
