Are you trying to connect a computer via wireless through the router or direct line with a Ethernet cable?Are you trying to connect a computer via wireless through the router or direct line with a Ethernet cable?
You can't post conmments that contain an email address.
The netgear router installation will set up the internet connection during install. Download the Router driver from netgears website and install on the computer/s then your up and running. it appears you wireless card is seeing the router so just install the drivers and your set.
Yes you simply need to hook up via an Ethernet cable, open a browser type in the routers address, login with username and password, and then you can edit any setting you like. Then when finished you save settings and reboot router.
installation guide below.
en-us-support.belkin.com/app/answers/detail/a_id/2533
When facing the router, Globe/Internet LED is on the right. Below are the LED indicators; Check the steps below:
Wireless Security - This light will only turn on if the wireless security is enabled.
Wireless-Computer Status - This light will turn on if a wireless computer is connected to the router.
Wired-computer Status - This light will turn on if a wired computer is connected to the router. Connect the wired computer to any gray port on the router. (There are 4 gray ports).
Router Status - Power light. Solid blue means the router is on and ready.
Modem Status - If this is off, it means the router is not connected to the modem. Make sure the cable is connected from the modem to the yellow port on the router.
Internet Status - This light will indicate if the router is connected to the internet.
If this is the first time you are installing the router, then what is important is to get the router, wired-computer and modem lights ON. Once they are on, you may insert the CD that came with the Belkin router to setup the internet connection and wireless settings.
you may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
Connect the computer to the LAN port of the router, connect the modem to the Internet/ WAN port on the router, access the configuration page of the router (Example 192.168.1.1)configure the router as dynamic IP (DHCP) and configure the wireless settings as WPA or WEP encryption.
Whats the exact problem does it not connect at all?
Most routers don't need a disk to install anything.
Just plug everything in go to START click CONTROL PANEL go to NETWORK CONNECTION see if you have any connection at all. If you do your router could be blocking incoming data from the internet or other computers connected.
However in doing some research in your stated problem i did find drivers. They can be downloaded at the link below.
