SOURCE: My Panasonic TV - Panasonic TX37LZD85- switches
This is a Control Board defective. Please Change
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Testimonial: "Thank you for giving me another avenue to explore."
SOURCE: Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
My TV turns off while watching and message pops "Plasma no signal " . Please tell me what to do . Thank you
