Question about Kitchen Ranges
Cannot get any evidence of power. Checked circut breaker, seems ok. Last used 2 days ago.
  • bmduff Jun 28, 2009
    The oven is hard wired and built in to the cabinets, so impossible for me to check that.  I do note that on the circut breaker , while it will reset, it can be triggered easily with much less effort that the other breakers on the panel.
  • Kitchen Ranges Master
  • 13,433 Answers
If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Posted on Jun 28, 2009
Gas dryer pops circuit breaker
Number 1 Do NOT! use this dryer until it is fixed, it a a fire hazard. You will need to get the entire power circut checked for shorts. Make sure the motor has been checked under the same conditions as it is used in the dryer, with a capasitor and changing directions etc.
NEVER EVER !!! Change a Circut breaker with a higher value than the one which is there. You will burn the house down. This is a serious fire risk. The power cables over heat and arc then burn, if the breaker is not right.
Feb 01, 2014 | Dryers
Haven't used my ProForm 585s in a couple of months, now when I insert the key, no lights or anything. We've hit the reset button and checked outlets and such. Suggestions?
Your on the right track. If power is coming from the wall, it goes through the circut breaker ( red switch next to the power cord entrance), then it goes to the motor controller, the up to the console switch at the magnet/kill switch. To verify that you are getting power past the circut breaker, remove the motor hood. You can now see the motor controller on the left ( opposite the motor), it will have a red light on when it has power. If you dont see that light check the circut breaker.
Let me know,Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Proform 585 CS Treadmill
My Kenmore 70 series won't turn on. It was working fine 2 days ago. I checked the breaker box and everything seems to be ok. Everything else in the house is working. Now it's full of wet sheets and it...
check the door switch,if not that check the main fuse,unplug,remove the back and look down and to your right you will see a small white fuse,check that if you have a meter-mike
Feb 10, 2010 | Kenmore Dryers
The electronic oven control my whirlpool GS470LEM is blank.
Check the breaker to see if it is tripped turn it off and back on,
Jun 01, 2009 | Whirlpool GS470LEM Gas Kitchen Range
Was welding 10 min later mach. quit power was good circut breaker was good and fuses were good
it probably has a fuse for overheating safety, or else the feed motor fried
Apr 24, 2009 | Welding Tools
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
JVM1653 Just shut down with out warning
rich, after you take it down, open the housing and look for something like a white tube with two wires on each side, inside is a glass fuse .
Feb 18, 2008 | GE JVM1653 Microwave Oven
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
