2001 chevy citation, the a/c just quit working. A hissing sound was heard but the system shows it charged. Also now when the a/c is turned on the car engine runs rough and the engine runs hot, yet has plenty of good coolant. Also when the a/c is turned on now there is a loud click instead of a quieter click. Any ideas??
  • 400 Answers
You may have a faulty high/low pressure control switch which is not cutting compressor function due to low pressure of refrigerant in the system. The hissing sound is caused by a lack of refrigerant passing through the expansion valve. The other thought I have is that the thermostatic expansion valve or your reciever drier may be clogged.
Posted on Jul 02, 2009
What makes my 2001 chevy silverado airconditioning make a hissing sound when my air is on
Check the bearing in the end of the blower motor. They go bad and make a noise and over time will start rubbing and squealing like crazy.
Jun 12, 2017 | AC Cars & Trucks
Buzzing sound near rear tire
I had the same sound after reaserch I found it was the rear hub barrings, to check it take off the tire and pull on the lug nuts if the ole thing moves out and in that may be the problem item was cheep and easy to install it fixed my problem
Mar 25, 2014 | 2001 Dodge Neon
Tire leak hissing sound heard under hood from engine
Not the tires
Only makes a noise with the key on
or engine on
No idea without the car
Jul 23, 2013 | Nissan Cars & Trucks
What's your problem?Toyota Prado Grande 2004. Hissing sound at the rear air suspension and it drops (the body). Does not happen all the time. Bounces a lot quite often noticibly on a hot day, does
If you have Air suspension this can happen. The noise you hear like from an engine is actually the airpump trying to keep up.
The hissing is air escaping and the bouncing is an indication that the suspension is not fully inflated.
There are individual bleed valves so the system can be leveled by itself. The valve on one suspension unit may be leaking. Sometimes soapy water sprayed while the part is working and again while shut off will show a leak.
Some Makes have a diagnostic plug which a scanner can read to find the problem. Often a car is jacked or lifted on a rack and someone did not turn off the Air system and knocked it out of alignment.
I hope my solution is helpful and enables you to diagnose the problem now.
Jun 06, 2012 | Toyota Cars & Trucks
Check engine light comes on every three weeks about.reads secondary injection air system. can you help?
With regards to the secondary Air Injection system, this is basically an inspect and replace broken hose detail.
Leave the inlet hose disconnected and start the engine. Listen and feel for exhaust hissing at the check valves.The check valve(s) will make like a gurgling sound as air is drawn in However , if exhaust is felt or heard replace the valve. Get a scanner and turn off the check engine light. Hope this works out for ya.
Jan 02, 2010 | 2001 Volkswagen new Passat
Starts and idles fine but has loss of power during driving and I hear a hissing sound I never heard before
A hissing sound is usually a vacuum leak in the intake system. Look for loose hoses (with the engine running) and the source of the hiss. If you find a nipple hissing, it may have lost a cap (it may be a vacuum test port) that prevents air entry.
An aside note: be sure to change the timing belt at the proper time. If it breaks while running, the engine with suffer severe valve and piston damage (many penny!)
Nov 25, 2009 | 2001 Daewoo Lanos
2002 chevy citation, a/c fan works, system is charged, but no cold air. yikes.
need more info did u just use a charge hose to put freon in? or did u use ac gauges and if u did what were the readings?roniecon@gmail.com
Jun 28, 2009 | 2002 BMW 5 Series
A/c problems in 2002 buick rendezvous
it does sound like your AC line has a hole in it. I would replace the hose if you can see the leak. if you cannot see it then run a dye through the system and then put on the pair of UV leak detector glasses that you can buy at the parts store for like $15
Jun 24, 2009 | 2005 Buick Rendezvous
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
