Question about Craftsman Garden
Honda 4cycle engine Choke setup
I recently removed the carb. to clean it and i re installed it i was very carefull to set it up as it was.It will start when i pull the choke but when the choke returns to idle it stalls.
I have a honda model GCV190-AS3A Mower engine.
Is there a step by step setup guide ?
How can i repair it?
Thaks In Advance
Dom
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,495 Answers
Sounds like you dont have the run linkage hooked up right or not hooked up at all go to Honda repair help they can show you how to hook it up.
Posted on Sep 19, 2017
rockitman187
  • 2559 Answers
SOURCE: 2003 honda crf 150 will
The carb jets need to be cleaned.
Please take time to rate this fixya
Posted on May 12, 2009
  • 3567 Answers
SOURCE: starts and stays running with choke on. stalls
Pay special attention to the parts in red. DO NOT mix parts from the front carb with parts from the back carb. When removing adjuster screws and jets, count the number of turns to remove them, write it down, and replace with the same number of turns.
Go to the site below where you can see a parts diagram for your specific bike. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Go to this site and you can download a free PDF service manual.
www.carlsalter.com/motorcycle-manuals.asp Most all of the manuals are in English but some are not. There is no way to be sure without doing the download. You can always delete it if in a foreign language.
A “very helpful” rating on this answer? Thanks!
Posted on Jul 02, 2009
  • 1341 Answers
SOURCE: 2006 Honda Shadow Aero starts but won't idle.
check fuel level, u may need to check the flow of petrol to it,,Also if that does not solve you may need to service the carb and check fuel filter,air filter etc...
Posted on Aug 31, 2009
ollie reece
  • 1167 Answers
SOURCE: bike idles on choke , engine dies on acceleration drz 400 e 2003
try using that redex stuff get back to me
Posted on Sep 25, 2009
  • 5 Answers
SOURCE: I have Chipper/Shredder model 47321, 10 HP. I have
If you don't see an inline filter then the only filter is a screen in the fuel tank. Sounds like the engine is not getting the fuel it needs. Check the tank and clean as nessesary the screen maybe plugged. If you leave fuel in the tank for long periods of time with out using a fuel stabilizer your carb may need cleaning. Old untreated fuel turns into a varnish like substance. Check your fuel bowl and make sure there is not any dirt in it. You don't mention the engine manufacturer but, mine has the carb adjustment on the bottem of the fuel bowl. I have always used a fuel stabilizer and keep the tank full (filling it with a screened filter) with a added inline filter. In 20 years of my chipper-vacs life never have I had fuel problem.
Posted on Oct 12, 2009
It star with hoke on the maximum position only, is i throttle it dies imediatly. WHy ?
The choke setting required for starting is related to the temperature. In cold weather, a full choke is normally needed ; in normal temp (70 degrees F) a moderate choke may be all that is needed. Of course, once the engine starts, you may need to adjust the choke as the engine warms up - when ready to ride, you will want to have zero choke set. Hope this helps !
Jun 07, 2014 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
250trx honda runs only with choke on
needs a good carb cleaning ,if u have good mechanic ability u can go to you-tube and enter your bike for cleaning carb.
follow directions to a T dont cut any corners and use proper tools
be carefull not to loose any parts and take your time & dont
rush .any questions call me during the week between 8:00 am and
4:00 pm 1-270-556-7357 mobile
Feb 02, 2013 | Motorcycles
Poulan pro honda engine stalls as auto choke lever moves
Hi, when you say you cleaned the carb, did you strip it down and blow all the jets out with compressed air? If so, check that you have fuel flowing into the carb. If all this is ok check the valve clearances. Regards Phil.
Jun 24, 2012 | Poulan Garden
Craftsman dlt 3000 16.5 honda engine will only run if the choke is closed
if it still won't run after cleaning the bowl...you will need to remove the small jet inside the bowl that allows vaporized gas to be pumped into the carb..it is very small you will need a needle or something similar to clear..it usualy is next to the bowl float and is vertical to the carb..good luck
May 31, 2012 | Garden
Engine won't run with choke off
An engine that only runs choked is most likely starved for fuel. The main jet in the carb needs to be removed and cleaned with a piece of fine wire. If you have welding torch tip cleaners those work very well.
Turn off the fuel valve before removing the main jet! You will lose the fuel in the bowl so a small pan to catch that is always a good idea.
Honda replacement carbs have become very inexpensive for the jobbers so getting a new carb is also a solution if the carb is seriously plugged or corroded.
Be safe and good luck!
Nov 23, 2011 | Honda Garden
My 1993 Honda Knighthawk wont run.
The slow circuit of your carbs are dirty. you need to remove the carbs from the bike and thoroughly clean the internal passageways and jets. that should solve the problem. Always drain your carbs for storage and use fresh gas when you start up after long storage.
May 15, 2010 | 1993 Honda CB 750 Nighthawk
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Engine only runs with choke on
dear honda 750 your problem is a pluged main jet you must completley disasseble the carbs and give them a good cleaning with carb cleaner and comp air visually check to make sure you can see light through the jets after cleaning. your choke system by passes the jets that is why it runs on the choke setting only. hope this helps jim
Apr 12, 2009 | 1998 Honda VF 750 C Magna
Starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Apr 09, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
3,635 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
