Question about ASUS Eee PC 701SD 8G Notebook
My eee pc 701 sd linux wont fully shut down
When i select shut down the computer goes through the process tells me its saving settings and shutting down then the screen goes off.however the fan still runs and none of the light go out on the front (power light, battery light, and wireless LAN light)
My Eee 701 has started playing up, It is running with windows XP with a 1Gb sd card and it was working fine end of last year but have not used it since then until last weekend. I use this as a mobile pc...
Virus attack is a possible cause.
Always make sure that your antivirus is updated regularly. And your Windows updates are on. This increases security of your system.
Try booting in safe mode and run antivirus.
Steps to boot in Safe Mode:
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
Then scan your system for viruses through your antivirus.
If this doesn't work then, select Safe Mode with Networking as an option and access internet and update your Antivirus first then, scan your system.
If you have problems in updating your antivirus, please use following link to scan your system, Make sure you are in Safe Mode with Networking while you perform this step.
wish you all the best :)
Apr 26, 2010 | ASUS Eee 4G Notebook
Tip
EeePC 701-sd
If you Own a eeepc 701-sd you can get it to tell you when the piggybacking router is switching you out of their network,just manually configure the settings and learn to interpret the different "not connected" pages posted, each page gives a different type of error message,mess around with the settings and soon you will be able to duistinguish the difference between the messages--Linux only!
on Sep 05, 2010 | Computers & Internet
I have an Asus PC Eee 701 with Xandros, but all my peripherals (USB ports, videocam, SD slot) don't work. Where can I downolad the correct drivers? TM
Hi friend,
You need to select your model no then you can download the drives...click on LINK for download.
With Regards
Avnish kumar
Jan 09, 2010 | ASUS Eee 701 Netbook
I HAVE NO USER MANUAL FOR ASUS EEE PC 4G (701)
Hi Brian,
I assumed you were looking for the EEE PC 701 (XP) Manual and not the Linux version..
If so, you can get the manual from here: http://rapidshare.com/files/312178229/EeePC701SD_XP_0730.zip.html (Click on the "Free User" download option)
Cheers, Ed
Nov 25, 2009 | ASUS Eee PC 701 Notebook
Just trying to upgrade my asus eeepc 701 sd to take a wireless broad band heuwai modem
Ive tried this configuration many times if you ask me people connected to huwaei post thes things stating certain modems are configurable under linux,in a decent way but in fact they just want you to buy a modem which will never configure on a day to day basis properly.
i suspect this is a fraud to get you to pay£20--£49.99 for their dongles.
The basic problem is the auto wizard under linux does not recognise their modems--proceed at your peril!
Nov 03, 2009 | ASUS Eee PC 701 Notebook
My Asus Eee PC 701 SD has a stuck control key.
Shut it down (not hibernate), remove power supply and remove battery. Wait 30 seconds before reinserting battery. Boot the system.
In this doesn't solve the issue, your keyboard might be dirty. In that case you should clean it. Be careful if you choose to use a vacuum cleaner that you take measures to prevent your keys from getting into the vacuum cleaner.
May 05, 2009 | ASUS Eee PC 701SD 8G Notebook
Eee 900A goes through fast start then blacks out
Must be common problem. Linux is the operating system
yes you just lost linux, it needs re-doing but with an external CD ROM drive unless it has a partition
for recovery in which either F10 key will do it or another key check the manual for RECOVERY of operating system its not a big problme but it takes few hours to solve
Mar 13, 2009 | ASUS Eee 4G Notebook
Cannot connect to web on EEC PC 701
Hello Lil' ol Lady, (LOL)
Are you able to check your network connection? Go to your control panel, click on Internet Options, click the Connections tab, then the LAN settings. Make sure the Automatically detect settings is selected and nothing else. close all windows and retry your Internet. Good Luck.
Feb 12, 2009 | ASUS Eee 4G Notebook
Can a WEbcam be installed
Most 701 models came with a web cam built in.
You can install an external one easily.. just plug it in to the usb port.
Previous poster is wrong... why would you need a Cd drive ?
You could either download the drivers from the webcam maker's website, or simply copy the file from the CD to a SD card with another computer. If you have a home network setup, you could simply copy the files via network file sharing.
If you have the linux version of the EeePC 701, then make sure you buy a compatible webcam that has drivers in linux.
Jun 19, 2008 | ASUS Eee 4G Notebook
Prob in PC
Are you using an installer with SP2? check your devices under my computer if all are ok.
Sep 20, 2007 | Microsoft Windows XP Professional With...
ASUS Eee PC 701SD 8G Notebook Logo
181 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
