Question about Garmin Rino 130 (14 Channels) 2-Way Radio
I need a battery cover for a rino 130 where can I get one?
  • 3 Answers
Contact Lindsey at Garmin Support - 1-800-800-1020 or 913-397-8200, back cover is about $14.00
Posted on Dec 18, 2009
3 Suggested Answers
  • 20 Answers
SOURCE: Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
Posted on Sep 21, 2007
  • 3 Answers
SOURCE: my rino always says searching for sattellites
Once your rino travels more than 600 miles from original satellite fix you need to - Go to main page / satellites / options / new location.
Should take about 15 minutes to locate new satellites.
How do I get a new battery for my Garmin Rino 530 HCx?
buy one :
https://buy.garmin.com/en-US/US/shop-by-accessories/batteries/lithium-ion-battery-pack-rino-/prod1166_010-10569-00.html
Jul 26, 2014 | Garmin Rino GPS
It shuts off after about 2-3 seconds of powering on.
This is usually a symptom of weak batteries. Make sure that your batteries are fresh/fully charged, and that there's no corrosion build up on the battery terminals or the connectors inside the radio. Corrosion can be removed by rubbing the contacts firmly with a dry cloth (heavy buildup may require a fine wire brush, steel wool, or sandpaper). If your batteries are more than a year old they're probably due for replacement.
Bill B
Mar 30, 2010 | Garmin Rino 130 (14 Channels) 2-Way Radio
My rino always says searching for sattellites
Sep 09, 2009 | Garmin Rino 130 (14 Channels) 2-Way Radio
Back cover where that contains the batteries broke
Contact garmin at garmin.com, this is not an accessory, that you can buy anywhere, so send them an e-mail and see what they say.
Mar 31, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
Rino 130 5.8 version
I opend my unit and see that the mic is disconected from its posts. so i am looking to repair that issue. it looks like the posts are too short or recessed?
Sep 13, 2008 | Garmin Rino 130 (14 Channels) 2-Way Radio
Rino is burning through the batteries.
sounds like the battery needs to be replaced, mine last for days. it may have burned a memory into the battery
Jun 18, 2008 | Garmin Rino 530 GPS Receiver
Sep 20, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 130 Shut Down
I had the same problem; mine would shut off when bounced around too.
I used a #0 phillips screwdriver (very small) to take out the 6 screws that hold the case together, Carefully separate the face and back because there are wires that can be broken if you pull them apart too fast.
After you get the case apart, lift up the circuit board at the bottom and you will see a small blade pin that sticks out from the side where the batteries are and is supposed to slide up into a contact on the circuit board. I guess over time it starts to wiggle and get loose so I carefully bent the pin (very slightly so it would rub the inside of the contact.
So far I have tested it by dropping and beating it up a little and it seems to have fixed the problem.
Hope this helps.
Jun 16, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 130 (14 Channels) 2-Way Radio Logo
580 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
