Question about Toro Lawn Mower With Toro Power Tools
Mower leaves uncut strips between blades.
Had shop install new blades same problem and level the deck. same problem..
  • 33 Answers
Measure blades on a level surface.place each blade side to side and see if their is a difference,all measurements should be the same,if not you have a bent deck or a spindle that is bent.
Posted on Jul 12, 2009
Z2654 leaves a strip uncut about 2" every pass.
you have resharpened the blades I assume and cut some off the ends also .buy a new set of blades and install them
May 28, 2016 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
Bad boy mower
need to level deck
Aug 11, 2013 | Garden
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Mar 24, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
302 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
