Question about Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000
Pump will not always start in low speed but always starts in fast speed
    Problem Solver:
  • 10 Answers
This is a simply problem to cure. if you open the connection box on the pump, you should find 2 capacitors. you may even find one of them has melted!, replace both units, like for like, paying special attention to the values uF the two units will have different values. this should do the trick!
Posted on Jul 08, 2009
No slow speed, only fast speed
Always state your MAKE and MODEL when asking for help with regards to your product or item.
Dec 06, 2017 | The Health & Beauty
What can be the cause of it not starting?
diesel truck
most non starting problems will be air in the fuel lines , pump. could be stop solenoid not working
diesel engines need fast cranking speed so if the batteries are low then hard starting will result
Sep 28, 2016 | Cars & Trucks
Periodic stalling at slow or fast speeds. It would always restart immediately once it stopped. Gradually it got more frequent over maybe 10000 miles. Now it is almost immobile. Nissan dealership in Fife ,...
The fuel pumps on these cars seem to fail gradually. The car will stall / hard start for quite a while. Sometimes problem is worse when fuel tank level is low. I replaced fuel pump and no problems.
Apr 18, 2017 | 2002 Nissan Sentra
Intermittent jet problem on Spa form hot tub - low speed jet works, when button is pressed for high speed, it starts runs for a few minutes then switches back to low speed, then back to high speed again - ...
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
Apr 14, 2010 | Pool & Spa
Abs problem
check for warped rotors
Oct 02, 2009 | 2005 Chevrolet Silverado
I have a 96 chevy c3500 6.7 turbo diesel runs fine on hwy but while driving in the city it tends to die most times will start right back up but some yimes it takes 5 or 10 min then t will start up then...
YOU COULD HAVE A RESTRICTED AIR FILTER OR FUEL LINE OR FILTER.YOU COULD HAVE DEFECTIVE FUEL SUPPLY PUMP OR DEFECTIVE INJECTION PUMP.YOUR IDLE SPEED TOO LOW OR FAST IDLE INOPERATIVE.
Sep 02, 2009 | 1996 Chevrolet C/K 3500
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
2500hd dies then starts and dies again
CHECK AIR FILTER FOR RESTRICTION. A BAD SUPPLY PUMP. OUT OF FUEL. BLOCKED FUEL RETURN LINE. AIR LEAK IN SUCTION LINE. RESTRICTED FUEL FILTER. INOPERATIVE FAST IDLE. LOW IDLE SPEED AND DEFECTIVE INJECTION PUMP.THIS IS A LIST OF THINGS TO CHECK.
Jul 25, 2009 | 2002 Chevrolet Silverado
Pump will not start on low speed
It sounds to me as though there may be a problem with the small run capacitor on the motor. If that has failed the motor will fail to start on low speed.
The motor shop should know what they're doing as this is a common motor issue. Take it back to them and explain the problem to them.
Kind Regards,
Ian Kime.
Jun 02, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Over heating when traveling at lower speeds
Your water pump is junk - Mazda uses ford parts and they are known for the vanes on the pump deteriorating ( when you go faster what is left of the pump starts working and circulating the coolant, going slow there is not enough vane left on the pump to circulate the coolant efficiently) - a good flush wouldnt hurt either, //// to put it into perspective> kind of imagine a fan with the blades shortened, on low no air is really circulated - but put it on high and it may push as much air air it normally would on low, same thing is happening under your hood!
Feb 04, 2009 | 1995 Oldsmobile Aurora
Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000 Logo
155 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
