Question about Panasonic Televison & Video
Panasonic hdtv has no picture or sound
I plugged in a second television in the same place no it doesn't have sound or a picture.
    President:
  • 1,077 Answers
The most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC13 50 in. Rear Projection HDTV Does anyone know how to reset the timer when the picture doesn't come on (black screen)?
Turn on the television after the new DLP bulb and housing are inserted into the chassis.
  • 2 Move close enough to the set to reach it easily. Hold the "VOL" button on the front of the television, while holding the "SPLIT" button down on the remote. Do this for 5 seconds. Note that some models require holding the "PIP" button on the remote in lieu of the "SPLIT" key. Verify which model is relevant prior to beginning the process.
  • 3 Verify that the reset took by waiting for a message to appear on-screen indicating a successful reset. Additionally, the "LAMP" indicator on the front of the television will go out.
  • Oct 16, 2011 | Panasonic PT-50LC13 50" Rear Projection...
    The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
    The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
    Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
    Tv picture wont turn on
    Press the menu button if the menu does not come up then the issue is with the tv. If the menu does come up , try a second source such as a dvd player or a game system. you may need to change the channel on the tv or the input to get video and sound.
    May 06, 2010 | Panasonic PT-56DLX25 56" HDTV
    We have sound but no picture
    reset the unit by shortening the battery side...or you you just reset the unit by turning it off and after 10 to 15 seconds, turn it on again
    Nov 13, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
    Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
    After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
    You will hear a faint click comming from the back of set.
    After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
    The green light flashes and the bulb attempts to start.
    I found my picture will turn on on the third attempt of the bulb restarting.
    When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
    (note: The three start attempt happen after I do the button pressing
    1 time and I do not need further button pressing restarts.
    I think panasonic needs to let us know what the problem is.
    I called Panasonic and they told me to plug it into a wall plug by itself.
    I have it plugged into a multi plug adaptor now and have not tried this yet.
    Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
    No picture or sound
    first unplug the unit let it cool down ....plug it back in then reset the counter....press (-) volume on the tv and while holding down press the pip/split button on the remote and that should reset the counter...
    Jan 07, 2009 | Panasonic PT-50LC14 50" Rear Projection...
    No sound - one mo - nth old Panasonic 42" Viera HDTV 1080 picture excellent - tried all the routine remedies-LF
    call Panasonic, the unit is under warranty, the audio board may have failed. so call them for your nearest authorized Panasonic repair place. this will not cost you.
    May 27, 2008 | Panasonic Televison & Video
    Televison & Video Logo
    102 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
