Question about GE Refrigerators
My GE GSS22WGMCBB has heavy frost (ice crytals) builidng up on back inside wall. Refrigerator section is not cooling well
If you take that back panel off (four screws) you will find frost all over the coils. The defrost element at the bottom of the coils (two wires leading to it) might be burned up. For the time being you will have to take everything out of the freezer, take that panel off, defrost it with a hair dryer, and put everything back in. Your refrigerator will be fine for another few days and then you'll have to do it again.
Posted on Jul 19, 2009
Ice maker not working, newly purschased, put in
Hello there:
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
So make sure to check these really good and please let me know how this is going so i can continue to help you if needed
Best regards michael
Aug 01, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Freezer not cooling properly
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I have a ge externa refrigerator that does not cool on top shelves of the fridge or the freezer. it cools at the bottom just not the top. model # is ESS25KSTSS. Fan is workin fine and has freon. If anyone...
If the fan is working fine the next thing to check for is heavy frost on the back wall of the freezer section toward the middle to bottom area. If you have frost there you will need to remove the panel and with ref. off use a hair dryer to defrost the ice from the coils. After the ice is defrosted you will see a defrost heater at the bottom of the evaporator coils. This will be your problem Part number 51x10101 at about 64.00 or less. Hope this helps and good luck. Rick
Mar 09, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
I think my evaporator fan is out everything in fridge is warm to touch and ice is built up on freezer wall at rear of freezer and ice cubes will not freeze solid.also do not hear fan running any more
Hi there
I have found some stuff for you to read hope this helps you. Let me know how it goes.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | LG LRBN22514ST Bottom Freezer Refrigerator
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Temperature too low
There can be several reasons why the fridge is not cooling.
see the following notes from repairclinic:
Evaporator coils
Condenser
  • The defrost timer
Aug 29, 2008 | GE Refrigerators
Whirlpool ed22rf cools poorly on non freezer side.
Check condenser for dirt or dust, check back wall of freezer section for frost, if you find frost there is a defrost problem. Frost buildup on the surface of the back wall indicates that the coil inside the back wall is frozen over. Inside the back wall on the coil are heaters which the timer energizes to defrost at certain intervals. These heaters could have an open circuit, the defrost thermostat could be open, or the timer could be malfunctioning. To test the timer manually you can rotate the clutch head screw clockwise untill you hear one click. The heaters should come on and defrost for 18-22 minutes. The refrigerator should return to cooling after that time. If it does not automatically restart turn the screw once more to a second click and it should start.
Jun 08, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
GE Refrigerator - TFX22ZR (side byb side)
First, fully defrost the unit by turning it off and letting it melt out for 2 days...or take the inside panel off the freezer and defrost it with a hair dryer...(electricity and water do not mix...careful). Allow to dry. Clean the condenser under the unit. Avoid 'window shopping' to keep humidity out of the box. Restart the unit. Look at the compressor's largest pipe. It should frost and then clear to either ice, water or dry out....not continue to stay frosty after about 5 minutes. If no frost at that time, you have enough refrigerant. If this doesn't work for you, then the timer can be accessed from the back of the inside of the fridge cabinet. The heating element is below the coils behind the freezer....Just follow the wires....But...I'm betting my solution fixes your problem.
Dec 22, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
226 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
