Question about Whirlpool GU2400XTP Built-in Dishwasher
1 month old Partner III. Unit loads with water at
1 month old Partner III. Unit loads with water at start, but then nothing but a low pitched humm. This happens at all settings. Unit was unloaded, same thing happened. Unit does drain properly.
  • 999 Answers
1 month old? It's still in warrenty. Call for service. sounds like the motor will not start in the wash direction.
Eric
Posted on Jun 28, 2009
Kenmore HE2 problem
Blocked filter/pump probably,,,won't spin unless water been emptied out
Jun 17, 2013 | Kenmore HE2 Plus Front Load Washer
Light on but nothing happens
Sound like the diodes stuffed FOR THE MAIN UNIT.
I'd be taking back to the supplier/ STORE
Apr 30, 2012 | DeLonghi BC0261 Espresso & Coffee Maker
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Compressor won't restart when pressure gets low. How do I fix it?
The unloader is designed to release the pressure in the discharge tube after the unit reaches set pressure. The unloader is usually located within the pressure switch and is enabled with a small lever opening a valve (some look like tire stem). You can verify if it is working by cycling compressor and listening for release of air after unit reaches set pressure. Some compressors do not have a built-in unloader relying instead on loose fitting parts to bleed out air. On these units, air leaking back from the intank checkvalve will cause problem of loaded/backpressure and the motor cannot overcome. Easy to verify if checkvalve is leaking; with pressure in tank remove the discharge tube at the checkvalve and spray soapy water. Clean or replace this valve as needed. Good luck
Apr 20, 2011 | Campbell Hausfeld Air Tools & Compressors
Our 3 month old machine started making a high pitched squeel the other day during the wash cycle. Now it has started on the rinse cycle on the Quick setting. Model LD149.
I share your frustration with the same machine. Mine is approx 3-4 months old and within the first month i had a leak at the base of the machine which was fixed under warranty. The following month the machine started leaving water in the base of the unit after the wash cycle was complete. LG claim it is an electronic fault in the circuit board. I have refused repair and am now claiming a replacement with them. I don't feel it is acceptable for a machine that's only 3months old to give problems such as these.
Mar 28, 2011 | LG LD-1420T1 Dishwasher
I have a Quiet Partner III, when I press start it doe not come on. The clean light flashes when the door is open, but when I close it and try to start it nothing happens
The clean light is blinking due to an error in heating the water. I have put together some instructions on resetting the control so you can use the dishwasher and what to look for as far as cause.
Follow the link and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool Dishwashers
My Whirlpool Quiet Partner III is collecting dirty water after the garbage disposal has run. Is this problem the dishwasher or garbage disposal?
The drain hose under the sink needs to be tied up,above the point where it enters the drain pipe or disposal,water is feeding back into the unit,run the disposal more often also this helps prevent this from happening.
Aug 19, 2009 | Whirlpool Dishwashers
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Hitachi EC12 Compressor- weird hum
The burst of air you hear as the compressor shuts off is the cylinder unloading so it will not have to restart against a high pressure load. If the unloader is electrical it would explain the hum that you hear. This could be a normal function.
Aug 24, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Whirlpool GU2400XTP Built-in Dishwasher Logo
87 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
