Question about Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w
How to scan from printer to pc
Want to scan a document to fold in computer
3 Suggested Answers
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: Scanner or PC?
Neither is it a prob with the computer nor with the scanner.
Let me guess,
either is your usb connection cable longer than 2m or you have connected the usb printer/scanner cable to a usb hub.
Do use a cable no longer than a max of 3m and do connect the usb cable directly to the computer usb slot.
Posted on Oct 18, 2007
pineworks
  • 4345 Answers
SOURCE: I would like to scan a document from my brother
Hi there
There are lots of programs to be had.
You need a program that you can use on your PC with this program you scan it to your PC and then print it out, ok you need a program like art or photo or paint or some thing like this that have a scan in it.
Read more below.
The best program to put on your Pc is what I use and it is Free you, it is called PagePluse SE, you should try it you can do all sort of things with it but there no scan on it, just scan your photos to the your pc with another program witch has scan on it and put them in the SE program and you can do any size you wont and after adding text to it or backgrounds you can send it to the printer and print, an other program I use for scanning from the printer to the PC is called PainShop Pro 7 witch is a old program there newer ones out now but I am happy just using the old one it does the trick.
The Free version is Called PagePluse SE you not need the version 9.
Ok here the link to download the PagePluse SE program and it not a free trial it a free, there is one you can Buy but this is all you need download the free one it just as good.
Click Link = http://www.freeserifsoftware.com/software/pageplus/index.asp
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 13, 2010
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
How to scan from machine to PC
  • 1. Turn on your all-in-one printer and computer. Check the connections between the two machines.
  • 2. Lift the printer's document lid. Examine the scanning surface and the underside of the lid for dust and fingerprints.
  • 3. Put the document you wish to scan face-down on the glass. Use the alignment markers to help you square up the object. These are usually found on the left-hand edge of the scanning area.
  • 4.Close the printer's document lid slowly so the document does not shift position.
  • 5. Select a scan resolution. The higher the dpi (dots per inch) count, the sharper and more detailed the image.
  • 6. Push the scan button. You may have to do this on the printer itself or on your computer.
  • 7. Check the preview of your scan on your computer. Depending on your all-in-one printer and software, you may have to prompt your computer to display the preview for you.
  • 8. Edit the image as it appears on your computer if you want to make changes. Your scanning software might let you enlarge, resize or otherwise manipulate the final product.
  • 9. Accept the scan and save. Return the original document to a safe location.
  • Aug 10, 2012 | Ricoh Aficio MP C2051 Color Copier wDOC...
    Cannot Scan Document into my computer after doing the following: click scan; click download to computer; clicked OK; receive message Downloading Application; then receive message cannot retrieve...
    A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
    If that doesn't help, try the steps below:
    1. Disconnect the printer from your computer.
    2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
    2. On your computer, go to Control Panel > Printers and Faxes.
    3. Delete the Lexmark print object.
    4. Reboot your pc.
    5. When your pc turns on, reconnect the printer.
    6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
    Aug 24, 2011 | Lexmark X4690 Wireless InkJet Printer
    Pls help with scanning a document then emailing it. When I place the paper on the scanner, press scan to pc, it scans then displays the message "Scan error. Try scan from computer or see...
    you can scan from the computer using hp solution center.look for it's icon on the desktop or on the laptop.double-click on that and it will give you scan options.you scan photos or documents using that program.
    if you installed the software cd that came with the printer then you should be able to use solution center
    May 26, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
    HP L7680 prints fine but during scanning process it starts the scan but after light bar gets to end then it locks up and must restart the printer
    Hi there!
    To check if the issue is with the hardware part of the printer try to make a copy of the same document. if it fail to copy the document it can be with the document or with the scanning mechanism of the printer.
    If you are using the Automatic Document Feeder, make sure that the document is flat because the sensor is sensitive to crumples or folds, try another document to isolate the problem.
    If you are scanning using the flatbed glass make sure that the setting is set to the correct paper size that you are using.
    If after checking all those and you still experience the same issue there is a utility from HP that will recognize where is the issue coming from and it also provide a Fix or a resolution to the problem
    You can download the HP Scanner Diagnostic Utility from this site: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2512009&lc=en&cc=us&dlc=en&lang=en&cc=us
    Just select your Operating System, click Next and select Utility and under it click on HP Scan Diagnostic Utility. Save it on your computer. Once the download is finished click Run and on the utility select your printer model # and click on Diagnose
    ** To check your exact Operating System click Start> right click on Computer/My Computer click properties**
    Hope this helps!
    May 08, 2011 | HP Officejet Pro L7680 All-In-One Printer
    How do I scan a page from Scanner and transmit it to my PC?
    Welcome to fixya,
    4. Close the printer's document lid slowly so the document does not shift position.
    Hope this Helps.!
    Dec 19, 2010 | Canon Office Equipment & Supplies
    How do I scan a document? I press scan and it asks me to wait and then nothing happens.
    You didn't mention which machine is it for. Either way scanners need software listening on the computer side to accept scanned images.
    So assuming that there are no hardware (including cables to PC) problems, you should check that proper driver and application software are installed. Re-installing is a good idea.
    Good luck
    pls. vote for better service... Thank you
    Nov 20, 2010 | Office Equipment & Supplies
    Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
    Please clarify a few things for me so I can help you solve this issue.
    Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
    OR
    Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
    If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
    There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
    To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
    Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
    Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Scan to computer
    perform your scan operation via your PC's start>programs>HP>solution center rather than the printer console
    Jan 30, 2009 | HP Officejet 5610 All-In-One InkJet...
    I need to scan a document from the printer (HP psc 950) to my PC
    If you are using a Win Xp computer than try to scan using scanners and cameras utility under control panel. Else you can download HP scan drivers and perform scanning. Also 3rd party scan softwares such as photo shop will allow you to  scan.
    Jan 22, 2009 | HP PSC 950 All-In-One InkJet Printer
    Brother DCP-J140w Wireless Compact Inkjet All-in-One Dcpj140w Logo
    19 people viewed this question
    James Cagle
    James Cagle
    Jim Keysor
    ctnozil
