Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60 in.rear projection Philips Magnavox
My screen has progressively gotten worse. At first, when I would turn on the TV, the screen would go from large to small. Now, picture is getting smaller and smaller. What could it be?
  • dgibson5 Nov 09, 2007
    I have a Model 9P5031 C102 and recently, the screen begins to shrink in and out on the initial few minutes of power on. Sometimes it will remain in the shrink position, a small picture in the middle of the screen. Sometimes a few power on and off's will clear the problem temporary. Also noticed that when it is on full screen, it seems that the screen has shifted about half an inch toward the right. Vertical size looks normal. When the tv is warmed up,sometimes taking up to an hour or more it seems to stay on full screen ok, however, I still can see that the screen has shifted 1/2 inch to right.
    Thanks in advance for your help.
  • Stephen5 Dec 20, 2007
    I have Model# 9p5040c102 that did the same. For a month, when powered on, the screen would zoom in and out for about 10 minutes before becoming normal. Then last week it would remain in the shrink position for 30 minutes or so, a small picture in the middle of the screen with no sound when picture was small and sound would return when picture was full screen. Sometimes a few power on and off's would clear the problem, but it would flick in and out finally becoming normal and would stay normal as long as the TV was on. Yesterday, nothing, black screen and no sound. Can anybody identify the problem? Is it fixable?
I also used the product from My TV now works great and it saved me several hundred bucks! I was nervous about doing it myself at first, but the step by step guide made it as simple as it gets. I recomend it to anyone who needs this repair. THANKS ED!!!
Posted on Jul 11, 2008
  • Philips Master
  • 3,459 Answers
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here.
Posted on Jun 20, 2008
Poor picture quality. Picture also tends to curve
The curving is caused by bad digital convergencr chips (2) located on large signal board. They need replaced along with blown pico fuses and the convergence resistors. Chips are huge compared to a regular IC. 2" x 1.5" and they will be bolted on fairly large heatsinks. Cloudy picture is most likely the coolant needs replaced in the picture tubes. This needs to be done approximately every 5 years.
May 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a philips big screen tv that has double color around edge. iI was informed it was convergence integrated circuit were is that located on the set
It is located internally and can be identfied by looking for the large heatsinks (aluminium) the ICs (two of them) would be labelled STK...
Sep 18, 2009 | Philips Magnavox 60PP9701 60" Rear...
My 60 inch tv is not turning on do i need it
Was this tv made between 1995 and 1997? The problem is in the large signal board. It has the flyback on it. You will need to find a servicer.
Sep 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
60" Projection Screen Phillips Magnavox won't turn on
Check the site - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
181 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
