Question about Krups XP7230 Compact Super Automatic Espresso Machine
Error code 06 on a Krup XP7245
I have tried resetting the machine. This is my second one. The first one went back the same day I bought it as the would not work not error code just wouldn't. Thsi one I have had for 6 months and now KAPUT!!
Remove calk-filter in watercontainer..
Posted on Sep 21, 2009
What does e8 mean on the display?
http://www.dyson.co.uk/support/am04/am04-irsbl/my-machine-is-not-working/e1-e5-e6-am04
Jun 03, 2015 | Dyson AM04 Hot Cool Heater/Table Fan -...
How do i reset a dryer display when i get the fault code F 06 on this machine Whirlpool AZB8670 ??
it's not normal for this to happen but you might have to get someone with a computer to reset it for you ask an engineer to check for you
Jan 03, 2015 | Whirlpool Washing Machines
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
electrical)
- Distributor switch fault
- Faulty electronic boards
connection
- Actuator switch short-circuited
Dec 08, 2013 | Krups XP Coffee Makers & Espresso Machines
Error 06
Look for a water leak, it may be to the base of the machine and will release out the vent UNDER the drip tray if you tilt the machine forwards. There are many places for it to leak, not easy to find, I have an outer housing with cutouts to allow me to see inside while it's running. Hydraulic ram and the distributor are the most common places to cause error 6 but there is also a tricky one where the valve on the pump releases to the drip tray. A leak is the problem, finding where/which is the hard part.
Nov 29, 2013 | Krups XP7245
Bizhub error code
Have the fusing unit replaced. One attempt only to reset if you continue to get the code the machine can catch on fire! That would ruin a perfectly good day. If the code comes back after this procedure have a qualified Konicaminolta Service tech look at it.. First power off the machine with both switches. Wait 10 second turn on the switch inside the machine then holding down the Utility/Counter button turn on the second power switch on the control panel keep the utility /Counter button down until you get Trouble reset then touch get a OK then power off the machine wait ten seconds power back on.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 26, 2013 | Minolta Office Equipment & Supplies
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
Konica minolta DI 750 error code SC36-06
Hi this error code is an issue with the fuser unit it could be the thermistors lamps ect you will need to check the parts and replace worn or end of life parts if you hold down the utility key and power off the machine then power back on the machine holding the utility key wait about 39 seconds then take your finger of the utility key on the screen trouble reset will appear press the screen power off the machine then back on again this will reset the code
Feb 09, 2011 | Office Equipment & Supplies
Sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Jan 21, 2009 | Sub-Zero 700TR
Machine Fault Error No 06 at start up Model is Krups XP7240 Expresso - not listed in product list
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
Jul 10, 2008 | Krups XP4030 Espresso Machine
Krups XP7230 Compact Super Automatic Espresso Machine Logo
2,735 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
