Question about Epson Office Equipment & Supplies
Epson cx8300 scanner not work but printer working
My printer work perfectly ok till recently. It just show up ''Cannot properly communicate with scanner. The carriage unit may be locked depending on your scanner model.'' and refuse to work.
Easy solution~ : )
connect the printer usb plug to usb port that direct from the motherboard. not the front side usb port of casing. : )
Posted on Dec 12, 2009
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Call tech support.
Posted on Jun 29, 2009
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
Tip
How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.<br /><br />If you have an error, delete all following entry before you rerun the software.<br /><br />delete registry key: <span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG</span><br /><br />and delete folder: <span style="font-weight: bold;">C:\adjustment program</span><br /><br />To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.<br /><br />Here How to use this software:<br /> <ol> <li>Download the adjustment program (see below)</li> <li>Extract the file you have downloaded</li> <li>Go to The extracted folder then click tricks-collections.bat file</li> <li>Now set the date setting in you PC to 11 April 2008,</li> <li>Run adjustment program by click AdjProg.exe file the click accept</li> <li>Click Particular adjustment mode then select destination and printer port then click OK</li> <li>Select Waste ink pad counter from the below window and double-click to execute it</li> <li>Click [Check] button to check current protection counter's value.</li> <li>Then Click [Initialization] to reset the protection counter to the initial value.</li> <li>After finishing, you can change the date back to normal.</li></ol><b><br />Link Adjustment program for Epson CX7300, CX8300 and CX9300F</b> <ul> <li> Adjustment program for epson CX7300: <a href="http://www.mediafire.com/?8wrkugah2mj">http://www.mediafire.com/?8wrkugah2mj</a></li> <li> Adjustment program for epson CX8300: <a href="http://www.mediafire.com/?0xfnrgarvuj">http://www.mediafire.com/?0xfnrgarvuj</a></li> <li> Adjustment program for epson CX9300F: <a href="http://www.mediafire.com/?o020wlaf6te">http://www.mediafire.com/?o020wlaf6te</a></li></ul> <br />
on Mar 09, 2011 | Office Equipment & Supplies
My epson cx8300 prints a pink instead of a yellow color and a green instead opf a violet one. how do i adjust this?
I think your printer head is block. If yes
#clean printer head by using hot water or alcohol.
and another regon is your printer ink cartrige / refill ink may be alternet. if yeas
#set the cartrige or ink properly.
Thank's
Feb 09, 2011 | Epson Stylus CX8300 Printer
No printer software for my epson stylus cx8300
Here is a link to the website to download your driver. You'll need to make sure you download the correct driver for the operating system on your computer:
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1171
Mar 31, 2010 | Epson Stylus CX8300 Printer
I lost my disc for epson printer CX8300/DX8400 to load onto my computer... how do i find a new disc or any other solutions please?..
if you lost your epson printer installation disc your can still acquire a copy from the site of the product manufacturer heres the link:
http://www.epson.com.ph/epson/drivers/driver_download.htm?mode=3&catid=4&productModel=4&catid=&pid=1171&ad=1&downloadType=Windows
Nov 25, 2009 | Epson Stylus CX8300 Printer
Epson cs5500 scanner software wont work
try downloading the latest drivers from epsons website. if coping is working and printing is working, it sounds like a software problem. Its possible there is a bug in the scanner part of the drivers.
May 07, 2009 | Office Equipment & Supplies
Epson scanner 1670 scans a blank page
I can not copy scanned pictures from my epson perfection 1670 scanner from windows xp. Everything works from taking the scan and putting into a folder to be copied. When I bring this folder up to copy a blank 4"x4" or so window shows. I've used this scanner for 2 years or more and have had no problems till now.
Mar 15, 2009 | Epson Perfection 1670 Flatbed Scanner
Epson 3490 scanner red light flashing message that printer cannot properly communicate with pc
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
Jul 16, 2008 | Epson Office Equipment & Supplies
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
579 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
