Question about Whirlpool GHW9400 Duet Washer
Error code F06 - Whirlpool GHW9400 Duet Washer
2 Suggested Answers
SOURCE:
  • 1527 Answers
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Posted on Mar 22, 2009
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Sep 11, 2009 | Kenmore Elite 45986 Front Load Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
