Question about IBM ThinkPad T43 Notebook
Wireless / cable connection
How do I switch from wireless to the cable connection on an IBM ThinkPad T43?
  • Caldwell Nov 07, 2007
    Hi R -
    I mean the LAN cable for hi speed internet access where there is no wireless available.
    P
    Sergeant:
  • 324 Answers
By cable connection, do you mean a LAN cable or a phone cable or something else? Let me know and will see what I can do to help.
R-
Posted on Nov 07, 2007
  • Ron Roske Nov 07, 2007
    OK. Thanks for the additional info. Now we're on the same page.
    Plug that cable into the side of the pc. Go to start, then to "Connect to", then show all connections. See of there is already a Local Area Network shows up. If it is there, it should not have a red "X" over it. If that is the case, your LAN should take off and work. If not, get back to me.
    \R-
2 Suggested Answers
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
Radio switch off
To switch ON the radio function use combination of Fn + F5 keys.
Regards;
Hasan
Dec 26, 2009 | IBM ThinkPad T43 Notebook
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
I reloaded xp on IBM t43 but wireless lan is not working. i downloaded driver but still no good
Is the wireless turned on?
Make sure the antenna wires are connected to the WiFi card.
Nov 16, 2009 | IBM ThinkPad T43 Notebook
    Note:
Oct 07, 2009 | IBM ThinkPad R30 2656 Notebook
Adding wireless printer to thinkpad T43
If you have a wireless router, the printer will talk to the router and not to the thinkpad. You would have to establish a connection between the printer and the router. Then share the printer to print.
If you dont have a wireles router and you are trying to connect your thinkpad to the printer directly, the wireless card in the thinkpad should be in the adhoc mode. ( See Wireless card properties )
Hope this helps
Thanks
Ranjit www.supportminds.com
PS: Dont forget to rate me if you got your answer.
Aug 13, 2009 | IBM ThinkPad T43 Notebook
Ibm thinkpad t43 wifi drivers
ibm t43, wifi not configured, contact your system administrator
Apr 17, 2009 | IBM ThinkPad T43 Notebook
Wireless adapter not visible
Is it not physically connected or is there an on off slider switch thats turned off ?
Still does not explain why its not showing up in device manager.
Apr 15, 2009 | IBM ThinkPad T43 Notebook
Wireless signal intermittent
First make sure you have the latest update for your bios and wireless device, your os is probably non preload so clean any access connections utility provided by ibm, rather than using the ibm thinkvantage access connection make sure to use the windows own utility to control the wireless device
Feb 11, 2009 | IBM ThinkPad T43 Notebook
Can't set up wireless connection
On IBM laptops, you have to hold "FN" key and push the function key that has the wieless icon on it.
Sep 27, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
327 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
