Panasonic plasma hdtv with crazy red coloring
I have a 65 inch plasma hdtv and randomly the screne will get a pink red coloring flashing in lines horozontaly, somtimes only on ligher colors occationly the whole screen will be pink red. the last time this happened it went away after about a week. it turns pink red for satilite tv as well as x box but not dvd please help me i need to play halo
5 Suggested Answers
SOURCE: Red Excited Pixels when screen in is black
power supply is miss fireing.
Posted on Jul 27, 2007
SOURCE: I have a Phillips 42
I wanted to share my solution to this problem. Not only is it an easy fix (aside from taking the tv apart) but it also explains some of the strange methods I've read that have worked, such as taking out padding from behind the boards or putting a magazine under one side and even tapping on the tv for a temporary fix.
Granted its only been a few days of it working but I tell you this....It's not done the half black screen once! And trust me when I say it was doing it constantly.
Ok so first off the problem definitely lies in the upper/lower buffer boards. On the model mentioned by the OP (same model I have) it's located on the same side as the power button (right side when you are looking at the tv).
Ok so you've got the tv openned face down on a non static surface. Btw I was shocked at how many youtube videos I found of ppl working on their tvs while its laid flat on their sofas!
When you are looking into it you will see on one side there are two vertical boards hooked up to another board more towards the center. These two boards are your upper and lower boards that provide the upper and lower picture. The problem I was having was in the lower section of the tv going black so obviously that corresponded to the lower board. (They are labelled upper and lower if you look closely)
So here is what I did:
I noticed the lower board was not sitting flush so I unscrewed the one screw on the bottom and noticed how much of a gap was in the screw hole. The problem was it was screwed down in such a way that one of the connections going to the main board was not making it's proper connection. So I just gave it a little push towards the center, held it, and screwed it back down.
That's it! It's fixed now. No need for replacing anything. Just poorly drilled holes and a few things not lining up correctly!
So hopefully anyone else that's having this same problem might have some luck in using this fix. Good Luck!
Posted on Mar 15, 2009
  • 834 Answers
SOURCE: westinghouse 32
if it is after warm up then it could be your T-con board
if it is all the time cold or warm then your panel has an intermitant and will need to be replaced
Posted on Dec 01, 2009
SOURCE: 42 panasonic plasma TV I have no red color in tv
I unplugged all the cables that goes from the cable box to the tv and then plugged it back in. The color red canme back. It was easy.
Posted on Feb 03, 2010
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
Everything is red on my panasonic th-50ph9uk.
I have a Panasonic plasma 55 inch and the screen went green and pink is this fixable
Apr 07, 2013 | Panasonic TH-50PH9UK 50 in. Plasma...
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Red lines on plasma TV
It may be because the tv is unable to display the signal coming in....
Feb 17, 2009 | Panasonic TH-50XVS30U 50 in. Plasma HDTV
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
If you wish to get some details; visit the site linked here. Pull up older posts.
Mar 13, 2017 | Televison & Video
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
