Question about Garden
Need help fixing a small troy-built tiller. the carb fell off and I am having trouble putting it back together. I can't get any throttle response when I squeeze throttle.
  • jeremykasten Jun 28, 2009
    Tim,
    this tiller has a 2 hp tecumseh engine it has a blck plastic flap on the choke
  • 234 Answers
Make sure that the linkage rod or cable is connected correctly. You should be able to see the throttle plate move with the choke open.
If you need more help, post a comment.
Thanks,
Tim
Posted on Jun 28, 2009
Throttle cable
Its usually put on as you install carburetor so you can turn or twist as needed then bolt carb on.
Jun 03, 2013 | Troy-Bilt Pony Garden Tiller
Troy Built 6.0 HP stored for winter. Fired up and
Most definitely. You aren't getting enough gas, probably because the float valve is gummed up. Drain the gas, put in a little carb cleaner and a little fresh gas. Fire it up. Do that a couple of time if needed, then fill tank with fresh gas. Use a gas stabilizer like Sea Foam to prevent this.
Apr 05, 2010 | Troy-Bilt Pony Garden Tiller
The governor is stuck wide open. How do you fix it?? Troybilt tiller reardrive 3 horsepower
have you gotten something stuck in the throat of the carb where the throttle butterfly opens and closes to control speed? check this,then check all moving parts on the carb and especially the governor spring that its not caught on something
Mar 31, 2010 | Troy-Bilt Pony Garden Tiller
Hi there i have speedy hoe model#352 i did tune it up and now i do not know how to put back small spring which is close to air filter ,and there is also about 1''of wire that conects to carburetor and...
I'm sorry I don't have a solution for you but I have a similar situation. Don't know what goes where. Do you have an Owners Manual for that unit? Much appreciated if could get a PDF copy e-mailed to me.
Feb 13, 2010 | Troy-Bilt Pony Garden Tiller
Troy built tiller starts chugs along and then kills full size mod
I'm sorry you are having trouble with your Troy-Bilt Tiller. I have a genuine Troy-Bilt and I miss the original manufacturer and the help they provided me with my 30 year old machine.
I believe your trouble is in the needle valve adjustment. If you check the bottom of the carb, you will find the needle valve. It should be open about 1 1/2 turns and then fine tuned open or closed a bit to get the best speed. There is the possibility that your carb is dirty inside and could benefit from some carb or injector cleaner. You may also benefit from installing a new spark plug as well. Sometimes, in older engines, you can benefit from using a spark plug one or two heat ranges higher. You will have to experiment with these options to find the best for your situation.
I hope you find these suggestions to be of some benefit.
Thank you for posting your question on FixYa.com
a
Nov 07, 2009 | Troy-Bilt Pony Garden Tiller
Hi there i have a troy built honda engine 2500 2.3 pressure waqsher and can not get it started. it will start for just a moment and then just die. almost sounds like it isnt getting gas but ive checked...
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. You can also use the Den Tek Brush to clean the jet in carb. if it has one. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller and Pressure Washer
The carbs are plugged. Take the bowl off the carburetor by loosening the nut on the bottom. You'll want to clamp the fuel line before you do this. That nut has a small hole that goes through the nut from side to side, and one that connects them in the center. Use a wire brush to knock all the deposits loose, making sure that the holes are clean and free of obstruction. Put it all back together, and it should run fine.
Jun 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tiller will not keep running
Have you tried squirting gas into carburetor to see if it will keep running? If that keeps it running as long as you are squirting gas in it, your carb need to be cleaned out/repaired.
May 26, 2009 | Troy-Bilt Garden
Troy-Bilt Tuffy 2006 model keeps having weird engine problems
Make sure you haven't used ethanol-blended gas in a briggs small engine. It will destroy the plastic internal carb pieces, thereby causing your carb to leak gas into the crankcase and flooding out the engine. If you check your gas it will be really thinned out, gassy smelling and black. It will also be overfilled.
Apr 25, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
