Question about Electrical Supplies
1st how do i caulcate the total amount of amps?
1st how do I calculate the total amount of amps used in my panel?
2nd how can I find out what the incoming amps are?
  • 2 more comments
  • djohns4u Jun 28, 2009
    Yes this is for my home's electrical panel service.
    I want to add a new breaker to my service and I want to know if the the service coming it will handle a new breaker. I would also like to know if in the future if I could add more breakers and at what amps.
    I'm not looking to wire it myself I just want to know if I have the availability to have a new breaker put in. Don't jump to conclusion before you ask all the right questions... I was not planing on wiring this myself just want to cut cost on getting a election to see that I don't have the right service...
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Are you talking about a house electric service panel?
    President:
  • 1,564 Answers
You'll need what is known as a AC clamp-on meter,but, I'll warn you they are very expensive. What exactly are you trying to survey? Power usage by appliances and the such?
Posted on Jun 28, 2009
  • 1 more comment
  • Dana Newcombe
    Dana Newcombe Jun 28, 2009
    Trust me when I say that, first of all it is illeagle to change your own wiring configuration unless, you are a licensed eletrician. Secondly, one small mistake can cost you your house or even possibly your life. I suggest you call in a proffesional electrician,Sorry!
  • Dana Newcombe
    How old is this house? Are all the appliances working correctly? Is your electric bill going up? So is mine.....Sorry that's all I can say.
  • Dana Newcombe
    Dana Newcombe Jul 25, 2009
    I appologize, you left me the impression that the work was to be done personally.
How many watts does a old gibson 21.6 cu ft freezer use
Check the nametag on the fridge and take note of the total amperage draw of the unit. That that reading, and multiply it by 120 volts and the resultant answer will the the total wattage of the unit... If you want to get it precise, measure the applied voltage at the receptacle where it is plugged in. Your 120 volt circuit may really be supplying 125 volts or more and that will effect the calculation....though minimally.
Apr 05, 2015 | Freezers
How to calculate npv
To calculate present value you need to type in all the other missing values and then press COMP and PV.
For example: if the future value is R5000, the interest is 12% p.a. compounded monthly and it paid over 3 years.
Type in 5000 and press FV
type in 12 and I/Y
Press 2nd F and I/Y and make sure P/Y says 12 (for 12 payments per year).
Press ON
press 3 press 2nd F N and then press N again (for 36 payments in total). Make sure your screen says ANS -> N otherwise the calculation will not work.
Now if if your payments are 0 (in other words you are not making monthly payments) then press 0 and PMT,
Otherwise, if you are making monthly payments for e.g. R200 a month, type in +/- 200 PMT.
Now calculate your original amount by pressing COMP PV.
If you made no payments your original amount should be -3494.62
And if you chose to add payments your original amount should be
2 526.88.
May 30, 2014 | Sharp EL-738 Scientific Calculator
TI-81 when turned on, screen is totally black, can perform calculations & barely see results on screen. is this a battery problem?
Adjust the screen contrast. Turn the calculator on. Press and release the 2nd key. Press and hold the down-arrow key to lighten the screen. If you go too far, use the 2nd and up-arrow keys to darken it.
Aug 08, 2012 | Texas Instruments TI-81 Calculator
How do I find what the percentage is . . . the amount is 4,117,484 out of a total amount of 163,715,657. I usually divide the amount by the total but when I use a calculator to check (by multiplication)...
100*4117484/163715657 gives me about 2.5%. Since you didn't specify the calculator your're using, I can't give you the exact keystroke sequence, but on a typical algebraic calculator it would be something like 1 0 0 * 4 1 1 7 4 8 4 / 1 6 3 7 1 5 6 5 7 =
On an RPN or RPL calculator, it would be
1 0 0 ENTER 4 1 1 7 4 8 4 * 1 6 3 7 1 5 6 5 7 /
Mar 04, 2011 | Office Equipment & Supplies
I do not have the manual. If I want to add or subtract do I put the total amount in and than hit the plus or minus key ? i.e., $128,000 -10000. do I hit the minus before the amount or after? -1500....
You can download the manual from
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
128000 - 10000 then press = or chain the calculation by pressing + or - and the number you want to add or subtract.
Sep 30, 2010 | Canon P170-DH Calculator
How do I find the standard deviation?
Here is a detailed exemple. Hope it helps.
Some comments on the various variables (should the information be needed. If not need, please skip it.)
1.All you have to do is follow the instructions key stroke for key stoke, but enter your own data.
2. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
55 [2nd][FREQ]3 [Sigma+].
3.If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
4. Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
5. The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
Check the theory you have been taught and try again. If that is not the type of statistics you were supposed to do, then give more information.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
HOW TO CALCULATE PERCENTAGE IN MICROSOFT EXCEL?
Hi nastyguy3000;
To calculate a percentage in excel you simply take
amount/total = percentage in your cell
Example A B Purchase price Sales tax (in decimal form) 800 0.089 Formula Description (Result) =A2*B2 Multiplies 800 by 0.089 to find the amount of sales tax to pay ($71.20)
Have Fun
Mark
Don't forget to leave a rating.
Feb 19, 2009 | Microsoft Computers & Internet
Loan Balance
set your p/y to 12( compounding periods per year). I think you are calculating for a one year loan?
Nov 18, 2008 | Texas Instruments BA-II Plus Calculator
Electrical Supplies Logo
102 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
