Question about Viking DFUD142D Built-in Dishwasher
Dishwasher is stuck in the drain cycle and will not turn off even when power button is turned off-control panel just keeps blinking "heavy" load
  • 3 Answers
Check flote switch
Posted on Jun 09, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
Drain pump won't turn off, all lights are blinking
Try pushing the cancel button. Try holding the cancel button down. If it'll let you select a cycle, try running a cycle. Try putting a large volume of water in there. It might either clear the pump or it will "see" the water going out be satisfied. If it remembers the cycle you last ran, or which cycle you usually run, run a cycle that it's not used to. That helps clear the computer some dishwashers. Failing that, try turning the circuit breaker off for a minute. Press every button on the dishwasher. There's a chance that that will help drain any power stored, making the computer forget what condition it was in. Failing that, try turning the circuit breaker off or for a day or two. Failing that, if you know what you're doing and you're not worried about voiding the warranty, open up the control panel where the main circuit board is. We can assume that if it remembered this cycle with the power turned off for a while that there's a battery in there to keep from clearing the memory. Find the little button cell battery and take it out for a few minutes. Then put it back in and turn the power on. There may a reset button hidden inside there or somewhere else on the machine. Find the manual at home or on the internet and look in the troubleshooting section. There might be a specific button combination to clear that condition.
To keep this from happening in the future, pick up and install a dishwasher air gap for around $15. It's really easy and keeps water from backing up into the dishwasher. They're actually required in a lot of cities.
Sep 15, 2009 | Asko D1706 Built-in Dishwasher
My whirlpool du931scgb1 dishwasher.on the front panel only the delay button and the heavy load button works. and if you use the heavy load button the washer restarts it's self every 10 seconds. thanks
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Aug 01, 2008 | Whirlpool Dishwashers
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Dishwasher almost fixed but won't pump water
Could be the motor is stuck. This is a common problem in dishwashers. With the power turned off, open the front kick panel and turn the motor a couple of times by hand. Then turn on the power and run the drain cycle to see if the motor drains properly.
Aug 21, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Viking DFUD142D Built-in Dishwasher Logo
235 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
