Question about iLO (2 GB) MP3 Player
No sound I am having problems with the earphones the ones that came with us had gone belly up and then had a old set and now when i listen i have to press down on the earphone extension to get stereo surround sound and if i dont i have nothing.
  • 8,596 Answers
Replace the player - cannot be fixed
Posted on Jul 05, 2008
New Bounty Hunter Discovery 3300 Metal Detector No external sound
Most earphone jacks have two functions. One, to provide signal to a set of earphones or headphones. Two, to DISCONNECT the path that would be amplified and sent to loudspeakers. If that particular contact on the jack is bent or broken, when you UNPLUG the male jack, the connection is NOT re-established!
Apr 22, 2017 | Bounty Hunter Land Star Metal Detector
My itouch earphone jack creates static in earphones.
sounds like the typical ipod and ipod touch common situation. It seems to be the dreaded headphone jack on the bottom or top of the device has gone belly up. You can either take it to your local apple store or look online and search your problem and see if anyone else has the same issues you have and see what can be done.You can send it to ipodsquad.com to get repairs or check your local apple store.
Oct 12, 2009 | Apple iPod touch
When I put my earbuds into my ipod touch only one side works
i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
Feb 14, 2009 | Apple iPod touch
Sound problems
Have you tried using a differant set of Headphones? If you still have the same problem with using other headphones, then it seems like there's a poor connection on the sound card from the headphone in input to the board. If your sound card works fine through normal speakers, then that's more then likely your problem.
The cheapest solution would be to replace the sound card rather then have it repaired, as it would probably cost you more to have it repaired then what it would be to buy one depending on what quality of sound your happy to listen to.
Dec 01, 2008 | Samsung Yepp YP-P2 Digital Media Player
Chang Jiang N958
assuming it is a wire earphone which comes bundled with the set then
as soon as u plugged in the set should detect and show 'earphone plugged in', if not the problem is with the earphone itself.
If it is ok and can,t hear, check for the user profile selected as 'Headset'.
Now turn on the radio.
To check whether FM is working or not [diagnostic verify]Warning: DO NOT CHANGE ANY SETTINGS
enter *#66*# to enter Factory mode. Go to the end of the menu & select FM Radio --> select any channel to listen hiss sound. If so the set is ok. EXIT now. Mind that the earphone wire only works as fm antenna for the device that's why radio is disabled by default till it finds the earphone is plugged in.
Keep some space blank in the phone memory as it may be the problem.
if the problem is something else then describe what is happening stepwise.
Oct 08, 2008 | Nokia N95 Cellular Phone
IPOD IS NOT WORKING
cuase youre earphones are lost.
Mar 04, 2008 | Apple iPod mini M9160LL/A MP3 Player
Can't adjust the earphone sound
Use the side buttons to lower the master volume, when your in media mode listening to your music, you have to use the side buttons or flip it open and use the side buttons by squeezing your finger between the big screen and the keyboard, they diodnt think that part out to well.
The ear Piece volume control your talking about only pertains to when your actually on a call.
Stupid set-up i know.
Dec 31, 2007 | LG enV VX9900 Cellular Phone
Sound Only Comes Out Of The Right Earphone
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 24, 2007 | SanDisk Sansa e200 MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
