Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
My Briggs & Stratton gives off a puff of blue smoke when I first start it. When in idle it will REV up & down and give an ocassional backfire.
    Sergeant:
    Champion:
  • 207 Answers
Sounds like you may have too much oil in the engine. Check your oil level.
Posted on Jun 28, 2009
How to replace ohv cam on 17.5 briggs model 31c707-1346-b2
I SET THE INTAKE VALVE AT .005 AND THE EXHAUST VALVE AT .003 AND THE EXHAUST VALVE MOVES ONLY HALF THE DISTANCE OF THE INTAKE. IT IDLES OK BUT GIVE IT SOME GAS AND IT BACKFIRES THROUGH THE CARBURATER AND SHUTS DOWN.
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have an old 3.5 hp Briggs and stratton on a masport lawn mower, it has started blowing smoke when it is unning, could someone give me a clue as to whether this is likely to be rings, vaulves, etc, or is...
Start by checking the oil level. It should not be overfull. If it is it will smoke, and it will soak your air filter , then foul your plug.
Check this first.
Let me know,Matt
Dec 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine starts and runs fine until i run about 5 pieces of branch
what color is the fire at the sparkplug? if it is blue it is good, if it's red that means that your spark is weak probably your coil is weak replace your coil
Jun 05, 2010 | Yard Machines 24A452G700 205cc Briggs ...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Sep 11, 2009 | Briggs & Stratton Garden
Briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Aug 20, 2009 | Briggs & Stratton Garden
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
773 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
