Question about Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply
Dell 4400 won't power up,Flea lightworks, battey ok all possible cables and memory repluged CPU replaced, capacitors look fine no hot spots. ?
  • gary desotelle Jun 29, 2009
    CAN I CHANGE OUT CURRENT DELL 4400 1.6 P4 BOARD WITH A DELL 4400 1.7 BOARD ? , OR WAS DELL TO PROPRIETARY? , I'M WILLING TO BUY AND TRY.
  • Dell Master
  • 13,433 Answers
Hi
the difference on the 1.6Ghz and 1.7Ghz is the processor, so the board should be exactly the same, so yes you can.
If you look up the model details from both boards I can compare.
Posted on Jun 29, 2009
    President:
  • 987 Answers
Your motherboard BIOS seems to be corrupted ..pls replace the motherboard..
Posted on Jun 28, 2009
Dimension 4400 won't power on. Flea light on. No
The Mother Board is seems to be dead please try to reset the BIOS by the help of the Jumper if the problem persist then you have to repair the board.
Jan 20, 2010 | HP Computers & Internet
Won't turn on - power led comes yellow & blinking
Please perform the steps mention:
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. Good Luck.!!
Aug 27, 2009 | Dell OptiPlex SX270 PC Desktop
4400 dimension dell power light is light green solid, motherboard is solid green but cpu will not power up
Refix RAM memory.
Pull cmos cell for 10 minutes so all settings defaults.
Reconnect ATX power connector from smps to motherbord.
Also change your smps .SMPs is on back side of cpu on top it is square box.
Also check that cable from cpu power switch connected properly to motherbord power on/off pin.
You can test motherbord with power on /ogg pin ground power pin withg any metal it is in corner of motherbord.
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Dell Dimension 4400 PC Desktop
Not powering up with steady orange power light
Did any one open the system, after which you are facing this problem?
If the 4 pin power connector is disconnected, you will face the same symptom.
This symptom can also appear if you have any external or internal devices electronically failed / Short circuited. Remove any external devices even external hard drive, flash memory devices, camera, printers etc and then restart the computer.
There is also a possibility of flea power, remove the power cable from the tower and press and hold the power button for 10 seconds, this will drain charge from the capacitors from the motherboard.
then connect the power cable and test if your issue is fixed.
if the issue is still not resolved, then we have to remove any internal devices, eg, add on sound card, video card, modem etc and then try powering up, if the issue persists there could be a problem with either the motherboard or power supply, which needs parts to be replaced and tested.
Jul 24, 2009 | Dell Inspiron 530s Desktop Computer
Dell 4400 won't power up Flea light works
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 28, 2009 | Dell Dimension 4400 Power Supply ** FREE...
Dell 8400 steady amber light, no diagnostic LEDs, high turbo fan
you will need to change your processor is like it is bad.
Apr 04, 2009 | Dell Dimension 8400 PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Feb 04, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply Logo
175 people viewed this question
Alun Cox
