How to get the latest bios version,old version l2850100.3/14/2003
Need older version 1.04 insyde bios for this machine
Windows ME is 15 years old. Please just get a new laptop.
Jun 14, 2014 | HP Pavilion N3410 Notebook
Tip
Hi, Simple Tip. To Avoid the problems in PC regarding the driver performance,...
Simple Tip.
To Avoid the problems in PC regarding the driver performance, accessories Malfunctions and software support always update to the latest BIOS of the Motherboard. it will help you to get the most out of ur pc.
Mostt Problems that i faced in PCs are due to the old BIOS versions that are not been updated time to time.
if you dont know what is the VERSION of your BIOS then here are the steps to know.
Go to the link http://www.softpedia.com/progDownload/CPU-Z-Download-6980.html
download the software called CPU Z.
now run the software and it will provide you the details on the motherbaord in Motherboard Tab. you will find the VERSION of the BIOS as BIOS Version.
Regards
on Feb 25, 2010 | Computers & Internet
Four bios versions which do I flash?
http://www.gigabyte.com/products/product-page.aspx?pid=4139#ov
Gigabyte GA-Z77X-UD5H
http://www.gigabyte.com/products/product-page.aspx?pid=4139#bios
F15q and F15o are BETA versions.
Meaning in actuality, they use the consumer as a guinea pig, and see what the results are. Then they might 'tweak it', and call it good.
Becomes an Alpha version then.
['Tweak it'.
Work the bugs out that have been found by the consumer]
My bad. Let me use the 'prose' they use,
"What is BETA?
BETA describes a new version that is reliable yet may not include all the features of the final product. During this phase we are previewing new features and gathering customer input to insure our product provides the best experience possible."
Moving on....
Next, the logical thought is; to download the Latest version.
The thinking is that the latest version has all the bugs worked out.
However this may be a fallacy for your particular motherboard.
The latest version may not work.
Makes you feel all warm, and fuzzy inside, huh? (NOT)
The procedure to use when updating BIOS, and using any version; is to make sure you keep a copy of the old one.
When upgrading, you will be asked if you wish to make a copy, of the old BIOS program.
YES, is the answer.
Something happens with the new version, you have the old version to revert back to; and at least be able to use your motherboard.
No BIOS? Might as well use the mobo for a Frisbee.
So,......looking at the different versions that you see, look at each one's date.
F5 is 03/28/2012. March 28, 2012
Indicates Enhanced overclocking capability.
What does F6 do, that came out April 26, 2012?
1) Improved Processor overclocking, using a processor based on the Sandy Bridge Core,
http://en.wikipedia.org/wiki/Sandy_Bridge
2) Brings support for using an Intel Xeon processor.
Now look at the next version, F7.
All the improvements you see listed for each version, are culminated in the newest version,
F14.
That is, the newest version that has proved to be stable.
Supposedly the 'bugs' are worked out.
The other two versions F15o and F15q, again; are BETA versions.
Should ONLY be used by those who have a lot of experience, and know what to do if it fails.
So this leaves us with F14.
HOWEVER again, make SURE you make a copy of the old BIOS version.
When updating you will be asked.
Regards,
joecoolvette
(ALSO, if your power goes out in the middle of a BIOS update, kiss the motherboard goodbye; unless you made a copy of the existing BIOS version.
This is why I, and others state; that unless there is a definite reason to upgrade the BIOS program on your computer -> DON'T)
Mar 17, 2013 | Gigabyte Computers & Internet
HI. I HAVE AN OLD PC AND I WAS HOPING I CAN MAKE WORK PROPERLY. I JUST CHANGE THE OS FROM XP TO W7 HOME PREMUIM. BUT IT KEPT ON REBOOTING, SOMETIMES IT WONT EVEN URN ON. SOMECASESIT TELLS ME TO UPGRADE MY...
how old is your old motherboard i its 5 - 6 yrs or older it might not support windows 7 and needs minimum of 2 gb of ram installed to support winows 7
hope this helpsyou
Sep 26, 2011 | EliteGroup P4M900T-M (V1.0) Motherboard
My computer doesnt know this printer My system is win7
some old printers will not recognised by Win7.Get latest bios versions and latest priter drivers from manufacturers website and flash the bios and reboot .If u have any problem send mail stating make and model with bios version
mohanraojagan@yahoo.com
Nov 06, 2010 | Samsung ML-1640 Monochrome Laser Printer
For save old bios and install new bios Dell OptiPlex gx620 (from version A05 to A011)
If you are looking to update your BIOS then you can obtain the latest version from Dell. There should also be a step by step guide on how to correctly perform the upgrade. However, unless there is a real need to upgrade your BIOS then you should not have to do this. I have worked on and custom built several PC's and have never had to update the BIOS.
Oct 09, 2010 | Dell OptiPlex GX620 PC Desktop
Msi P35 Platinum motherboard bios problem with the latest bios 1.10. I want to put an oldest version, the 1.9 but i don't find a solution...
Flash the new bios and replace with the old one. The same thing you do when you update the bios of your motherboard.
Oct 27, 2009 | MSI P35 Neo2-FR/FIR (P35NEO2FIR)...
CPU not support found !!
you need to change settings in your bios for the type of cpu you changed to
Or reset your bios to default it could still be set up for old cpu
Aug 02, 2008 | ASUS M2N-MX Motherboard
Panasonic CF-E1 Bios Update
Thats an old pc and flashing the bios (if not done right) could kill your pc..... with it bein so old and computers now being so cheap your best bet is to invest in a new computer. I have looked for your bios update with no luck either.
Jan 12, 2008 | Panasonic CF E1 PC Desktop
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
