Question about Troy Bilt Tb70ss Gas Trimmer
TB525cs trimmer runs until it is accelerated-surges then dies
This is a 4 stroke engine. with a previous TB 4s model I could open and clean the carb (not dirty) and that would solve this mysterious problem. I tried the same on this model with no success. It is as if there is an auto shut-down if the engine reaches a certain RPM. Like it can't maintain a constant fuel supply for the throttle increase given. There is a difference in the position of the choke settings of normal operation and getting it to run presently. I strongly feel this is a carburator issue and will attempt to clean it and the fuel filter again.
Thanks
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • Jim Parker
    Jim Parker Jul 01, 2009
    Did this solution solve the problem?
    Jim
Engine starts & runs at idle. Dies when switched to RUN & wont accelerate.
Sounds like its a fueling issue. With small tool 2 stroke engines when you pull the throttle you actually increase the amount of air the carb gets. In turn, this rush of air through the venturi of the carb draws more fuel into the cylinder. If your engine is cutting out or wont accelerate this is generally because the engine is either getting too much fuel or not enough for the fuel/air mix to burn effectively. It could also be air getting into the fueling system by means of a damaged fuel line or carb diaphragm. By all means clean the carbon from the exhaust and clean the air filter, they can only help the running of the engine. Hope this is of some help.
Apr 01, 2016 | Ryobi Curve RY26500 26cc Gas Trimmer...
TROY BILT TB 70 TRIMMER-NEW CARB KIT-NEW PLUG. NEW FILTER- NEW GAS--STARTS FINE IN CHOKE #1 POSITION- RUNS IN POSITION #2- WHEN SELECTOR IS MOVED TO POSITION #3 ENGINE DIES- ALMOST LIKE FUEL...
If you rebuilt the carb did you turn any of the screws on the carb while cleaning or take out, you might have just the low idle screw closed a little to much open half turn and see what happens. If you look at the carb where needle screws are located on the side,if you have two screws it will be stamped with an " L " and?or an " H " next to each screw. If you only have one screw then turn that one, to left to get more fuel. Good Luck...
Aug 27, 2011 | Troy Bilt Tb70ss Gas Trimmer
I have a Toro 4 cycle gas trimmer that won't stay running. Starts, then sputters, then dies. I've changed the oil, drained fuel & put in new fuel.
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Jun 30, 2011 | Garden
Hi, I have a Victa Tornado Plus Whipper Snipper that starts straight away and it idles but it won't rev up. When you try and rev the motor up it sounds like it is under load and the trimmer head only moves...
Hi and welcome to FixYa, I am Kelly. I know this is a 26 cc petrol engine on your trimmer but do not know if it is a 2 or 4 stroke engine. If you are in AU then it would be a 2 stroke. There are a few things that can cause this.
If you engine has a primer bulb.... Hold it depressed hard while trying to increase engine speed. What your trying to do by doing this is prevent air introduction via the primer bulb if it has a pin hole in it. If you can get normal speeds bu holding the primer bulb depressed HARD the primer bulb has a pin hole in it and must be replaced.
Also look inside the fuel tank at the fuel collection tube end. Usually there is a screen inside the tank. Some times the screen becomes coated with gunk and it has to be removed from inside the tank for cleaning.
If your carb has a fuel shut off on the side of it... unbolt the fuel manifold and pull the bolt out of the manifold. Models with this type of fuel shut off have a screen inside the manifold that has to be pushed out of the manifold and cleaned.
If after checking all of the above you still have the problem then it is time to remove the "L" fuel mixture screw on the side of the carb. BEFORE removal... rotate the screw clockwise counting turns until it JUST barely closes. Do not turn it tightly closed as the end of the mixture screw needle will break off inside the carb and you will have to replace the carb.
Then rotate the mixture screw ccw and remove it. Spray carb cleaner into the mixture screw hole to remove any debris.
IF your carb only has an "H" screw perform the same procedure above but for sure clean both the "H" and "L" mixture holes with carb cleaner. Wipe off the needles too.
Install both screws CW until closed and then reverse the number of turns CCW you counted before removal for EACH of the 2 mixture screws.
Make sure the FOAM Air Filter is NOT clogged with debris. Clean as necessary.
Start the engine and let it warm up briefly. Attempt to increase speed slowly to full speed. If the engine hesitates open the "L" mixture screw less than 1/8 th turn and try again. You should note a change in performance after rotating the "L" Mixture screw ccw. Begin rapidly throttling up the engine after EACH adjustment until the engine no longer hesitates or tries to stall upon acceleration from idle.
RUN the engine at TOP SPEED. Adjust the "H" Mixture screw until you get maximum engine rpm. You will NOT hurt the engine but it must run at MAX speed smoothly.
CHECK acceleration from idle to MAX again. re-adjust "L" mixture if necessary.
One last thing to check is make sure the gas cap is vented. Without a vented gas cap the engine will run briefly then perfromace will degrade substantially. Many times on trimmers I see people place plastic over the fuel tank fill hole and install a damaged cap. Replacing the cap has fixed many many trimmers with tank vent problems due to a bad fuel cap!
This should get you going again. If you need any more assistance or you still have the problem after performing the aboe please respond here with any updates.
Thanks for choosing FixYa,
Kelly
Jan 03, 2011 | Garden
Saw starts then dies. Changed fuel ine soaked carb
Check the fuel filter, air cleaner and muffler for plugging. Was the carburetor disassembled when soaked and did you use compressed air to blow out all passages? If the carburetor jet screws have been moved, preset them as follows: Turn both H and L screws CW to stops (lightly), then back out CCW each screw 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine speeds up somewhat but 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that chain stops turning, but the engine continues to run. Hope this helps!
Mar 30, 2010 | Garden
Stihl FS81(older style) brushcutter.New Carby dies under throttle
The problems you are having sounds very much like a blocked exhaust port/silencer. On these small two stroke machines it is normally the cause of lack of power or not revving. Happy gardening !!
Stantheman 19/09/2010
Mar 13, 2010 | Oregon Scientific Complete Carburetor for...
We are facing over heating and idling speed is not withstanding machine is getting off when we release the accelerator.
Use compressed air to blow the sawdust and dirt out from the cylinder and head. Clean the screen in the muffler. Make sure that the fuel/oil ratio is correct. Turn both L and H screws in the carburetor CW until lightly seated, then back out 1-1/2 turns CCW each. Start the engine and allow to warm up. Open the throttle and turn the H needle CW until the engine starts to speed up, but is 4-stroking. The correct position is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting is started. Let idle and adjust L CW until the engine runs fairly smoothly, yet allows the engine to 'follow the throttle' as you accelerate it. Set the idle speed screw so that the engine keeps running, but doesn't try to move the chain. Hope this helps!
Feb 22, 2010 | Garden
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
It dies when you give it gas.but it startes fine
When it starts it is running on the idle jet and when you open the throttle it is being starved of the correct gas/air mixture. Sounds like you have a blocked air filter or fuel restriction. Take off the air filter and try to start it opening the gas slowly. If that doesn't work, clean the fuel tank filter and try again.If that doesn't work, remove the carburettor and clean it with carb cleaner paying attention to any fuel or drilled holes in the body. Blow it off with compressed air and replace it. Ensure fuel tank has clean gas.
Apr 26, 2009 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
620 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
