The air blow inside but the fan dont work - Heating & Cooling
    Sergeant:
  • 340 Answers
Check your circuit breakers and that the thermostat is set properly I assume your speaking of the outside condensing unit. Tom
Posted on Jun 28, 2009
I have a 2005 Hyundai Tucson and it's nothing is blowing out the vent no heat or air I can hear the fan but nothing is blowing out what can it be
it could be that has a clogged filter, or the controlers dont activate the system inside to let the air flow.
Nov 23, 2016 | 2005 Hyundai Tucson
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Air conditioner in front dont work the back works but blows hot air,why
it may be front evaporator fan motor not working. check wiring connection and the fuse. or the motor itself defective.
look the indicator of a/c for outside(must OFF) or inside(must in 'ON').
Aug 15, 2012 | 2004 Dodge Grand Caravan
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
Breezair unit icing up
hi there,
in this case thermostat is not functioning if this a no frost or frost free,if the fans inside is not working too.feel if air is blowing,if no blowing of air inside freezer,fan is defective,try to check fuse on the line goin yo fan there is fuse there,replace fuse.also check thermostat if functioning,if you can disconnect thermostat,disconnect it check this by soaking into ice bucket with ice the filler bulb of thermostat,the two terminals hook it by multitester setting to R1,observed the deflection about 12 minutes if the pointer does not deflect to high resistance this thermostat is defective replace.this should be done by a/c technician.have a nice day,dont forget to rate me ,thank's
Apr 24, 2009 | Heating & Cooling
My ac
the second fan shuold work on and of not all the time and you probably need some more ac frion in your system.
Jun 11, 2008 | 1996 Nissan Sentra
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
