Question about Goodman CPLE24-1 Air Conditioner
Air handler is running but outside unit fan is not running. Just a buzzing noise.
    Sergeant:
  • 340 Answers
The buzzing if it is real loud is a very wore out contactor and could be the cause of your unit not running. Check your circuit breaker. you'll likely need service and have the unit cleaned for best performance. Good luck Tom
Posted on Jun 28, 2009
3 Suggested Answers
  • 40 Answers
SOURCE: goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
Posted on Aug 17, 2009
heatman101
  • 43501 Answers
SOURCE: Air handler working fine air conditioning
The compressor is either locked up or the start capacitor is bad...
The buzzing sound is probably the compressor trying to start and cannot get started...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Feb 04, 2011
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
My outside A/C unit is not coming on
might be it is relay problem in pcb. Pls check the cord then relay by a technician,
Oct 14, 2013 | Goodman Heating & Cooling
Replaced capacitor on fan in air handler now condenser will not run and fan on air handler will not shut off
fan relay stuck in & control fuse might be blown. see if you have 24 volts at outside unit.
Jan 17, 2013 | Gibson Heating & Cooling
Air handler working fine air conditioning unit outside-fan not working only get a buzzing sound
heatman101
Feb 04, 2011 | Heating & Cooling
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
Goodman a/c unit outside not coming on. buzzing
Aug 17, 2009 | Heating & Cooling
FAN ON COMPRESSOR SHUTS OFF
The loud buzzing noise if you have heat pump. May be comming from your reversing valve. To quiet this down. Turn off power to outside unit and squirt some oil into the reversing valve coil area. The coil slides onto a shaft this shaft has corroded a liitle and does not let the valve center itself. Alittle oil on the shaft help and quiets this down. DO REMOVE THE COIL WITH THE INSIDE AIR HANDLER POWER ON IF YOU HAVE POWER TO THE THE COIL AND REMOVE IT IT WILL BURN IT UP. yOU CAN JUST UNPLUG THE COIL IF YOU LIKE. RUSS
Jul 18, 2009 | Heating & Cooling
A/c outside not working
The buzzing noise is your contactor drawing in from your thermostat. The fan part of your unit is on a different circuit from your outside A\C unit. Your thermostat is the conductor of the orchestra tying ths units together. It may well be that your A\C circuit breaker has tripped, if it has there is a reason for it's tripping. Resetting the breaker by turning it off then on may get your unit running, but a technician needs to ascertain why it tripped. Or it could be a bad contact switch inside the outside unit not letting enough electricity through the switch. More than likely the first issue. Good Luck
Jul 15, 2009 | Goodman CKL36AR36 Air Conditioner
Heating & Cooling Logo
408 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
