Question about Pentax Cameras
Hi, My pentax optio WP don't work anymore. When i switch it on, it stops after 5 seconds. If i start it in read mode (blue button pressed whil i switch it on), it works, but the menu button dont't work and displays a yellow lock on the top of the screen. If i switch it on with the menu btton pressed, it displays ver 1.00 before to stop after 5 seconds If i switch it on with the menu and the blue btton pressed, it displays ver 36, then xxx test xxx and v 866-76 , 1.0001 before to stop after 5 seconds with 4 bips. What's wrong ? Can i fix it myself ? Best regards
  • 744 Answers
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u rate me!!
Posted on Jun 28, 2009
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
When i take pictures it is blurry and i don't know how to change it's setting becaue i can't read the language of it(france) what should i do?
Rotate the mode dial to the setup mode (screwdriver and wrench) and turn the camera on. Use cursor-left/right to select Set-up2. Use cursor-up/down to select the third item (speech bubble) and press the OK button. Select the desired language and press OK.
Jun 12, 2011 | Pentax Optio 50L Digital Camera
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
How do you use the self timer?
Press cursor-up and then use cursor-left/right to select the desired self-timer mode and press the OK button. Start the self-timer by pressing the shutter release button as usual. Full details are in the "Using the Self-timer" section on page 67 of the manual.
Apr 30, 2009 | Pentax Optio S7 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio s5i
Try taking out the batteries and re-inserting them after some time. If it doesnot work, most probably it is an hardware issue. Take it to the service center.
Sep 24, 2007 | Pentax Optio S5i Digital Camera
Pentax optio m20
Usually this is not a problem and you will find a menu option to do this. But, in some cameras the solution is to download them the same way as the memory card by plugging in the camera to the computer. Remove the memory card, and then plug in the camera.
Sep 18, 2007 | Pentax Optio M20 Digital Camera
Optio S4i - Freezing problem on green switch
I don't know for sure, but it sounds like it could be a memory card problem. Have you tried it with another card or no card at all? My S4i froze up completely from a bad sd card. The green power button would light up, but nothing else would happen. Pentax recommends Lexar or Panasonic sd cards from what I have heard. My new Lexar card hasn't had any issues.
Sep 08, 2005 | Pentax Optio S4i Digital Camera
Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Aug 30, 2005 | Pentax OptioWP Digital Camera
Cameras Logo
214 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
