Question about Jenn-Air Kitchen Ranges
Jenn-Air #SVE-47600. The control panel
Jenn-Air #SVE-47600. The control panel lights/digits don't work? Could this be the actual panel itself or something else? No info on panel at all, completly blank.
  • dsm810 Jun 30, 2009
    That didn't work. Also, there is not a "start" button. Only "off" and bake/broil/clean. I do get the audible sound when I press the buttons but no digital readout, completely blank like it's not connected.
    Should I disassemble and check to be sure the digital panel is connnected, wires loose? (yes, I'll cut the power off before I start that proceedure). Is there an internal fuse on the panel?
    I know I can buy a replacement panel, but also a "relay" panel. Both are pricey so if nothing else works is there a way to determine which one might be defective?
    Thanks,
    Don
  • 744 Answers
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours.
thank u
Posted on Jun 28, 2009
Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Oct 08, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
I HAVE A JENN-AIR SVE 47100 IT STARTED TO PRE-HEAT AND STOPPED AT 140 DEGREES NOW IT WONT GO OVER 100 DEGREES BROIL OR BAKE ELEMENTS NEITHER IS GETTING HOT CHECKED HI LIMIT IT'S OK NO TROUBLE CODES JUST NO...
Probably relay control. I have similar problem.
Best estimate I have had is $300, relay control circuit board, Part #12001689 costs $225.
I am getting a NON Jenn Air. Repair record not so good.
Check Consumer Reports
Feb 26, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
Fan on oven
Hello
Welcome to Fixya
My name is Huum,
47600 this can not be the complete model number.
please look at the sticker in the range and copy the complete model number.
If this is a slide in range the # will be behind the kick plate below
Please remember to leave a rating before you leave
Dec 11, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air model# Sve 47600. No display.
Before you replace the clock try cutting the power to the stove for 10 minutes. This will reset the clock and it will sometimes start working again.
Nov 11, 2008 | Kitchen Ranges
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Jan 14, 2008 | Jenn-Air JES9800A Electric Kitchen Range
The grease drain line is clogged on my Jenn Air Range/Oven somewhere between the grease storage bin and the bottom of the grill area in the area that is not visible. Is it possible to clean this?
Both grease drain lines on my Jenn Aire SVE 47600 are blocked - I have tried liquid plumber, but it hasn't cleared things up. Has anyone had this problem and figured out a solution?
Jan 13, 2008 | Kitchen Ranges
Kitchen Ranges Logo
194 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
