How do you put gas in the jet ski to insure gas will get to the reserve tank? do you pump with it on reserve or full?
SOURCE: Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
SOURCE: I have a 2004 kawasaki stx 12 f jet ski with fuel problems
i've got a 2004 kawasaki stx1200r jetski just changed the battery and thers no power and the fuse's are fine
