Question about Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply
Dell 4400 won't power up Flea light works
Dell 4400 won't power up, Flea light works
battey ok
all possible cables and memory repluged
CPU replaced.
passive yellow main switch lights, no green
capicitors all look ok
PSU benched tested ok. ??
  • Brian Lee May 11, 2010
    laptop or Desktop? For a lap top you can unplug the batteries and power cord. Then press and hold the power button. This is called a power-drain. If that does not work, take out the RAM, hard drive, and optical drive and do the power drain again. still not working, check the ram. Try one stick at a time in different slots.
  • Dick
    Dick May 11, 2010
    Next thing to try is replacing the memory one stick at a time. You could also have a bad motherboard.
    Novelist:
  • 79 Answers
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Posted on Jul 06, 2009
Dimension 4400 won't boot and the Flea light is amber
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
Dimension 4400 won't power on. Flea light on. No
The Mother Board is seems to be dead please try to reset the BIOS by the help of the Jumper if the problem persist then you have to repair the board.
Jan 20, 2010 | HP Computers & Internet
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
4400 dimension dell power light is light green solid, motherboard is solid green but cpu will not power up
Refix RAM memory.
Pull cmos cell for 10 minutes so all settings defaults.
Reconnect ATX power connector from smps to motherbord.
Also change your smps .SMPs is on back side of cpu on top it is square box.
Also check that cable from cpu power switch connected properly to motherbord power on/off pin.
You can test motherbord with power on /ogg pin ground power pin withg any metal it is in corner of motherbord.
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Dell Dimension 4400 PC Desktop
Not powering up with steady orange power light
Did any one open the system, after which you are facing this problem?
If the 4 pin power connector is disconnected, you will face the same symptom.
This symptom can also appear if you have any external or internal devices electronically failed / Short circuited. Remove any external devices even external hard drive, flash memory devices, camera, printers etc and then restart the computer.
There is also a possibility of flea power, remove the power cable from the tower and press and hold the power button for 10 seconds, this will drain charge from the capacitors from the motherboard.
then connect the power cable and test if your issue is fixed.
if the issue is still not resolved, then we have to remove any internal devices, eg, add on sound card, video card, modem etc and then try powering up, if the issue persists there could be a problem with either the motherboard or power supply, which needs parts to be replaced and tested.
Jul 24, 2009 | Dell Inspiron 530s Desktop Computer
Replaced 128mb with 512mb in Dell Dimension 4400. Plugged everything back in & turned on. Or at least think it is turned on; there is a green light for both the power button and hard drive lights. ...
If you have replaced the memory on a computer and it does not turn on normally that means that either the memory is defective or it is not compatible. Do you hear beeps when you turn on the computer?
Nov 26, 2008 | Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell laptop
Remove the CD Drive from the computer , disconnect the charger from the computer , flip the laptop and remove the battey, with the battery disconnected , push the power button for 10 secs to release the flea power , open the memory slot , remove both the memory sticks and then put back only one of the memory stick and then try restarting your computer. If it gives out the msg amount of memory changed , then Strike F1 to continue...
Apr 21, 2008 | Dell Latitude D600 Notebook
Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply Logo
646 people viewed this question
Alun Cox
