Question about Dryers
Dryer won't dry
I have a kenmore gas dryer, model number 110.72212100, serial number Ml4108223, thye D433-NAT-1206006-FM22.
i had noticed one day that the dryer didnt dry the clothes all the way, well i didnt think much of it untill i ran another load and it didnt dry all the way so i tested the dryer, i ran it for a few then opened the door and the clothes were still cold. the dryer is not heating when it dries therefore i have to drythe clother like 3-4 times before they are completely dry. i took thre back off the dryer but i dont know where to or waht to look for to try and fix it myself can you please help as i have a family of 5 and i desperately need me dryer on a regualr basis. the dryer is only about 6 yrs old. as of OCt.
  • lukeslp May 17, 2008
    the same thing happened to mine no heat
  • Dryers Master
  • 16,847 Answers
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Posted on Mar 25, 2017
3 Suggested Answers
  • 20 Answers
SOURCE: Gas/Electric dryer doesn't heat up
thermostat or a solinoid
Posted on May 07, 2010
  • 1554 Answers
SOURCE: hello folks, i have a
Here is the conversion kit you are looking for.
Gas Conversion Kit
Gas Conversion Kit
Posted on Oct 29, 2010
My kenmore dryer with serial number: DESR-NAT-1206006-FM22 doesn't have heat at all and my clothes are still wet. What to do before I call the repair guy?
Clean lint screen could be clogged a dryer sheet can sometime block the grille if a loads to large and heavy that will result in wet clothes.some dryers have an option for air dry if that is selec
Jul 24, 2015 | Kenmore Dryers
Dwsr nat 1206006 cv22 fm22 whirlpool ser
take a picture or more info where is it center side back wall ?
Nov 09, 2013 | Kenmore 74602 Gas Dryer
Dryer is not heating up. All cleaning of any build up has been completed. serial no: my1804125 type dwjr nat 1206006 fm22
There are multiple thermal fuses and also a thermostat and last is the heating coil itself.
Aug 19, 2013 | Ovens
Does it have a pilot light?
yes it is electronic called a pilot generator
Jun 14, 2012 | Kenmore Dryers
My dryer is about 7 years runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
Aug 23, 2010 | Whirlpool Dryers
My dryer appears to work as normal, but not heating. What could I do to fix problem on my own? Model: LGR4634EQ3, Serial: MJ0614112, Type: D433-Nat 1206006-FM22
You should unplug the machine and check the igniter to see if it shows any signs of damage. If it is damaged, replacing it should solve the problem. If it does not show damage there are a number of things it could be and it may save you money in the long run to call a techncian for service.
Dec 01, 2009 | Washing Machines
Heat will not work in dryer cleaned vent it was ok Crosley MOD BYCD3723W2 Serial MJ5202075 Type D433-NAT-1203003-FM22
I assume you have cleaned filter, look at rear of m/c and see if there is a red button, if there is, try pressing it. it may have overheated and cut out.
Other than that there are several possibilities for it not to heat, including faulty heater- faulty thermotat,-faulty timer.amongst others.
Hope this helps.
Dec 06, 2008 | Dryers
Dryers Logo
426 people viewed this question
Top Dryers Experts
