Question about Epson Aculaser C1100 Printer
MY EPSON C1100 PRINTER IS NOT CLEARLY
NOT PRINTING CLEARLY
  • 744 Answers
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..
or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Posted on Jun 28, 2009
Epson c1100 showing 'offline'
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 10, 2011 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Just replaced Black Cartridge still printing with wide black line on right hand side of page
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Mar 30, 2011 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 error code C0084. How is this code cleared.
Hi
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1374
Feb 15, 2010 | Epson Aculaser C1100 Printer
Epson C1100 - we get smudged copies and also not printing on far rhs of copy. Any ideas?
Drum needs cleaning. Also generic toner might not work so good as original.
Feb 12, 2010 | Epson Aculaser C1100 Printer
My epson c1100 is printing pink where blue should be?
maybe the print head for the other color is clogged
Oct 28, 2009 | Epson Aculaser C1100 Printer
Printing problem with epson c1100
sounds like a transfer belt problem - new photoconductor unit may be needed
Nov 21, 2008 | Epson Aculaser C1100 Printer
My epson laser printer help help
hold down the dustbin button while switching on to reset the printer after cleaning. that worked for me.
Aug 19, 2008 | Epson Aculaser C1100 Printer
Mac OS10.4.11 Epson C1100
I also use a Mac, (OSX 10.3.9) does this printer show up in the list when you activate the Printer Setup Utility (PSU) Do you get any error message from the Mac such as Printing Stopped etc. What shows when you click on the PSU after clicking on print etc.
Jul 01, 2008 | Epson Aculaser C1100 Printer
Not printing clearly
If the printer has been unused for a period of time, the ink can dry and clog the little holes. Try cleaning the metal connectors on both the cartridge and where the cartridge plugs in to the printer with alcohol.
Nov 07, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
