Question about Jandy Laars Lite2 Ld 175,000 Btu Heater
How to fox flo 6 problem on Jandy lite2 175n pool heater
Just replaced heat valve 2 weeks ago now getting flo 6 message
    Champion:
  • 246 Answers
Possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Posted on Sep 02, 2009
What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
Jan 17, 2015 | Pool & Spa
J-300 won't heat. FLO readout
FLO = It typically for a Flow Switch or pressure switch (heater is deactivated. Pump may also be deactivated).
It is most likely a flow/pressure switch failure.
Before you buy a replacement try running the spa with out the filter cartridge - Checking if dirty cartridge is the issue. Also check that all gate valves are all the way open & locked.
Jan 05, 2012 | Jacuzzi Home
When my spa is on heat mode pump on Low Speed it will not heat up. It says FLO and flashes do I have an air lock ??? Just changed pump a month ago.
FLO is a common signal for insufficient water flow through the heater tube. Do you see the low speed pump working? If you do, then try removing your filters, if FLO goes away then replace your filters with new ones. If not, your flow switch may not be working. You could have a legitimate flow issue caused from a clog or air-lock though.
Dec 17, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Rads get very hot when taking a shower heating not turned on
That is because the Flo-check valve(s) in the heating system is bad and allowing the hot water to "gravity" flow through the loops...
Get a HVAC professional to replace the flo-check on your heating system...
heatman101
Aug 20, 2010 | Bosch Heating & Cooling
I just purchased this car 6 weeks ago. I
if your car is the 3.8 L, place a small mirror between the firewall and the base of the valve cover- not real easy to do- shine a flashlight into the mirror for more light.....move the mirror a little to inspect for vacuum line (s) disconnected....they are a bear to connect but you'll get it, that might not be the problem, but it was on mine...hope this helps you in some way...thanks
Mar 04, 2010 | 2002 Mercury Sable
Why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Dec 19, 2009 | Heating & Cooling
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
Flo 6 showing on display panel?
DO YOU HAVE ALL THE WIRES CONNECTED? IF YES POWER MODULE MUST BE REPLACE
Jun 28, 2009 | Jandy Lite2 Lj175n 175,000 Btu Natural...
Kenmore Elite HE3 Gas Dryer no heat
Verify the glow bar ignitor is working. Also ohm it to specs before you replace a gas valve coil.
Mar 02, 2009 | Kenmore Dryers
Jandy Laars Lite2 Ld 175,000 Btu Heater Logo
203 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
