Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
Motor very noisy and then quit working
Replace Fan Motor
Product Label Says Not To Lubricate Bearings Because they
are permanently Lubricated. However, the bearing are actually gimbal mounted and held in place by a Flimsy Retaining Plate.
Lubrication will only evaporate under oven use due to the rising Heat.
Posted on Dec 30, 2007
Flotec pump 1hp motor has become too noisy when running
Is it the pump or motor. Pumps do wear out and need rebuilding or replacement.
Dec 17, 2013 | Plumbing
Kenmore ice machine circulation pump is making luoder than normal noise but is still pumping is it going bad
It could be the motor or it could be noisy because their is not enough water in reservior for it to circulate
by pouring water into resevior if it quites down its a lack of water if still as noisy it will be the pump
if it is a lack of water the water inlet valve is what i would suspect as the problem
and obviously the pump motor if still noisy when reservior full
Aug 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How does the timing chain adjuster work? My motor is a little noisy and I was looking to tighten my timing chain. the manual doesnt tell me how to just adjust it. It tells me how to assemble it (not very...
hi,if it is anything like the 400r,the tensioner will be automatic and non adjustable,normally the chain guides wear out before the adjuster reaches it outer limit,they are quite esay to replace but you need to take the cams out to do it,you will probably find that a lot of the noise coming from the motor is the clutch basket,as a matter of course they are quite noisy once you start to get a few km on the bike...cheers
Mar 21, 2010 | 1995 Yamaha FZR 600
Honeywell HCM-300T QuietCare 3-Gal UV Tower Humidifier Fan/Motor seems quite noisy and occasionally squeeky. Is this normal?
no, it will be needing to be opened up to check if anything is interferring with fan operation I.E. broken fan, motor bearings, anything touching fan
Jan 31, 2010 | Heating & Cooling
Noisy motor on fridge side which whirred to a stop
Hi, It sounds to me like the evaporator fan motor is faulty. They will quit working after they make a noise like that, bearings and windings.You have a door switch that stops the fan when you open the door, that opens the contacts on the motor. It should have come back on when closing door. Now you say it has quit cooling,so if this motor has not come back on and is not running quietly, it will need to be removed and replaced.It may be difficult for you if you are going to do this yourself, but if your up to it, you can save yourself some $.You can buy a new one at an appliance parts house, or get all of the info from you're unit and go online to order one.They have universal motors to fit also.It would be a 120volt sealed motor with a plastic or aluminum blade.Try and remove it yourself if you are able, if not you will need to call out the tech which can get costly. Best of Luck to you and please keep me posted.Have a good night, Sincerely,
Dec 06, 2009 | Washing Machines
When i start the dishwasher it will run very noisy and then stops
Sounds like your motor bearing is wornout.Noise is either from Motor bearing or impellor, It will depend on make of Dishwasher. But if it quits after running noisy and over 7years old, get a new one.
Apr 27, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Heating broke
Was the blower making strange noises before it quit? If not, does the blower work at all? perhaps only on one speed? If it only works on one speed, look for the resistor that goes with the blower motor. I assume it will be near the blower itself, but can't tell you where. An auto parts store can probably tell you. If the blower was noisy and suddenly quit, you will likely need to replace the blower motor.
Feb 04, 2009 | 2000 Renault 181
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
262 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
