Question about Plumbing
1987 GMC Dump Truck -- brakes engage by themselves
The brakes on our 1987 GMC dump truck are engaging by themselves when they get hot. After about an hour, they disengage and you can run the truck again. We have replaced the master cylinder and booster. We have bled the master cylinder per the instructions and also each brake line as instructed. The brake pedal seems to be working fine (not spongy). The brakes just get hot and engage without pushing the brake pedal.
    Problem Solver:
  • 16 Answers
It sounds like you have a broken spring in the hub, letting the brake shoes drag.
Posted on Oct 12, 2009
PTO won't engage in @986 freightliner dump truck while in neutral
the pto should be in constant mesh with a gear on the countershaft and be spinning all the time
the pump is connected when the operator moves a switch to allow air to engage a dog from that engaged gear to the pump
when you say win't engage , is the problem that the gears clash and grate when the switch is engaged or the engagement is smooth but it will not drive the pump
In the first instance put your foot on the clutch to stop the countershaft turning so that the dog gets to engage
in the second instance there is a shear pin to the pump drive that is fitted to prevent the destruction of the gear box if the pump should seize for any reason
Take it to an accredited shop that handles pto installation and repairs
Jul 06, 2015 | Miscellaneous
1990 GMC TopKick Dump Truck Shutdown Issue
Electrical problem. Something gets hot and stops working. Could be fuel pump or something in the ignition system, so losing spark. After it stalls, spray starting fluid in the intake and try to start. If it fires up and runs a few seconds, you know it's a gas problem. If starting fluid doesn't do anything, check for spark, it's probably an ignition failure-possibly the coil or the ignition control module. The module can be tested at a parts store.
Dec 23, 2013 | Cars & Trucks
1988 Chev GMC C60 dump truck brake lights will not work
if there is there is power both side of sw when pedal pressed
then there is brake in cable or clean the connections on rear light cluster and check earth /ground
Apr 12, 2013 | Cars & Trucks
1988 GMC dump truck brake light
If you have power in and out of the brake light switch, the next component to check would be the turn signal switch.
1020 hydro will not roll while in neautral
With the dump valve in it is fine to push it, however it is not a good idea to tow the machine as speed will force oil around the systen and try to engage the drive, so sorry you will need to push it slowley.
Mar 29, 2012 | Garden
I have a 2000 sierra 3500 dually dump truck and the brakes go to the floor. but have no leaks
If the brake pedal goes to the floor and there are no external leaks, then the master cylinder may need to be bled.
Feb 08, 2011 | 2003 GMC Sierra
1996 gmc k3500 dually 4x4 dump truck-front axle won't engage-very little power if any to front electric plunger on front axle to engage 4 wheel-checked fuses-they're good--is there a relay & where is...
have a 95 k3500 4x4,when i shifted to 4 hi,would not engage.never once heard any type of noise in the front end.replaced both actuators,fuse is,front will not engage.please advise.ken at 989-560-1906.or cobbish44@yahoo.com thanks
Jan 11, 2011 | 1996 Chevrolet K3500
Air conditioner does not engage
You probably have a bad low pressure cutout switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 14, 2009 | Heating & Cooling
Plumbing Logo
103 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
