Question about Garden
My mower makes a groaning noise and is slow
My mower makes a groaning noise when it is in motion, goes slower than it use to and seems to vary speed on its own. I have had it serviced multiple times with no improvement.
    Sergeant:
  • 353 Answers
Brake may be locking
Posted on Jun 28, 2009
Pride ultra making noises during ride
If you turn to the right and the speed of the clicking sound goes faster then your left wheel has the problem. The shaft key is a little loose and is shifting while running. If you turn to the right and the speed of the clicking sound goes slower then the right wheel has the problem. Sometimes a stick will become lodged underneath making contact with the wheel or rim making a clicking noise. These noises can drive me nuts. Scooter Doctor App
Jun 01, 2016 | Pride Health & Beauty
How can I slow down the speed at wich u can walk with the machine it is a propelled mower. Thanks
If the mower motor speed cannot be controlled, then you cannot control the walking speed.
And most transmissions are directly connected to the motor pulley so that if you slow down down the mower's motor, you also slow down the blade speed and cutting power.
Apr 05, 2015 | Garden
Why would a riding mower have the blade turning slow?
If speed varies depending on how much grass you are cutting, look for loose or badly worn belt. If constant slow speed when engine is running at full noise can only be a slipping on pulley or clutch. Most likely clutch. Normally slipping generates much heat so look to your clutch or pulleys. If drive key has separated there will be damage to shaft with metal dust showing.
Jul 21, 2014 | Toro Garden
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
I just replaced the drive belt on my Troy built auto transmission Bronco 42" riding mower, and now it goes a lot slower. The belt seems to be routed correctly
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Jun 05, 2011 | Mtd Drive Belt 42"
Mower is making a clunking noise when attempting to start and once running. blades seem quite loose.
I think that noise is because your blades are loose. They should be tightened right away because they could come off when you are using it with the possibility of injury to somebody. I have serviced some mowers with that problem. They make more noise when starting because they are turning slow and moving around more than when turning at high speed. Best regards and good luck.
Jan 02, 2011 | Garden
Slower engine speed in 4wd mode, 1st or 2nd gear (auto trans)
mcdevito75 here, I would figure yes, if your shifting while in motion, definetly yes, when you shift your changeing gear ratios in the 4 wheel drive or the transmission, this will cause the engine to slow but also make the gas pedal moe responsive.If you feel or hear this slowing down of the engine while standing still (at a red light) it"s most likely the computer contolled sensor in the tranny. I woulkd still check with my local shop for their advice too.
Nov 25, 2009 | 2004 Ford F150
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
