Question about Gateway FPD2275W LCD Monitor
Activating Audio ports on HCL HCM510LSA Monitor
I am not able to see the option for activating the audio ports on "HCL HCM510LSA Monitor" monitor... can some one help me...
    Problem Solver:
  • 13 Answers
Try using Windows Update or Microsoft Update, to install the latest drivers for your monitor, or using the included Driver CD that came included with your monitor.
If there is still no sound, you may need correct sound drivers for your computer. You can use Windows Update / Microsoft Update to also find the correct sound drivers for your computer.
Thank you very much.
Posted on Jun 28, 2009
How do I get P2210 monitor to work with USB with Dell Inspiron 15R that doesn't have a VGA port
The Inspiron 15R should have an HDMI port. You should be able to connect the HDMI to the DVI-D port on the P2210 with a cable like this: http://www.monoprice.com/Product?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2 . Alternatively, you can get an HDMI to Display Port adapter. Connect either cable with the notebook and monitor both off. Then turn on the monitor before turning on the computer. Pressing F1 should send the signal to the monitor. However, if you right click on the desktop (anywhere there isn't a program or icon), you should see some links for DIsplay options. You can use those to select the monitor resolution and whether to use both screens (extended or mirrored) or one at a time.
The most expensive option would be a USB to video adapter, see http://www.startech.com/AV/USB-Video-Adapters/ , or docking station. These come with VGA or other video output ports depending on the model. The USB ports on the monitor are just an integrated hub to plug in an external devices. It doesn't communicate to the display.
I hope this helps.
(The DVI to HDMI cable doesn't supply audio but that doesn't matter in this case. However, you may need to go into the Manage Audio devices control panel and disable sound on the HDMI port. Open the Control Panel (Windows + X in Windows 8 or from the Start Menu with Windows 7). Go to Hardware and Sound and then look for Manage Audio Devices under Sound. In the playback tab, adjust the default audio device by right-clicking on the appropriate device. Then click Apply.)
Jan 25, 2015 | Dell P2210 22 inch Monitor
I have no audio on P215H LCD Monitor
The audio cord is called HDMI, it's actually audio and video, now just because the monitor you have has a HDMI port does not mean your PC has one, you need a onboard video port that is HDMI or a graph card with HDMI.
Mostly good motherboards have HDMI or cards.
***** Now, the model you posted it does not have speakers so how do you except it to have audio ?
There would be HDMI on the monitor if it had speakers.
Apr 05, 2013 | Acer P215H LCD Monitor
I think ihave a audio on my monitor,so shoud it work
I see that you believe that you monitor has a built in speaker on it, if your monitor does have built in speakers on it then the only way to make the speaker get audio from the monitor is to have it hooked up on your computer using an HDMI cable connecting your monitor to the computer where audio and video will be rendered by the HDMI port providing Video and Audio to your monitor.
But if your monitor does not have HDMI on it or you computer does not have an HDMI port then that will be an issue, if your computer does not have an HDMI port then getting an expansion Video card that has one will make thing work for you and get you audio out of your monitor.
If you are only using VGA or a DVI cable connecting your computer to the monitor then audio will not come out as it should on the monitor.
I hope this will be informational and helpful to your concern.
have a nice day,
mvincentc
Oct 26, 2011 | Proview PL926WBi 19" LCD Monitor
No Sound LGW234T-PF
The LG W2343T does not have speakers. So you can't plug in a 3.5 mm audio patch cable between the computer's line out or headphone jack and the monitor. (Similarly, other devices can't provide sound to the monitor.)
Are you using a desktop or a laptop? If you have a laptop, make sure that the correct audio drivers are loaded for your OS and make sure that the audio isn't muted (look in the lower right on a Windows system in the tray for the speaker icon). On an HP laptop, we had to use the Component Services (Control Panel > System and Security > Administrative tools > Component Services > Services in Windows 7) and stop all audio services and restart them. Then reboot the computer to use the internal speakers at a reasonable volume.
For any unit with external speakers (required for a desktop, optional for a laptop) , connect the speakers to the audio out port (green for 3.5 mm for single connection speakers, see the manual for other speakers) or the headset port. Next make sure that the device drivers are loaded and correct for your sound card (or motherboard audio). (Control Panel > Hardware and Sound > Device Manager). If your sound isn't active, look at the Sound header. Then choose Manage Audio Devices and the Playback tab to select the desired speaker option. (Again these are for Windows 7).
If you still have no audio, make sure that the speakers have power (USB cord or AC adapter plugged in depending on the speakers). If it is USB powered, try a different port or a powered hub. If you have an AC adapter, check if it is warm. Some speakers have power/volume knobs. So check if they are on (if there is an LED, that is an easy check). If still no audio, try a different audio patch cable, if possible. Otherwise, try different speakers. There may be a damaged wire preventing the speakers from working. Depending on the problem and if your speakers are under warranty, it may be worth fixing or not.
Documentation for the monitor is available here: http://www.lg.com/us/computer-products/monitors/LG-lcd-monitor-W2343T-PF.jsp . Click on the Support tab.
If you want to use a stereo receiver with RCA audio inputs, you'll need an adapter or a 3.5 mm to RCA m/m audio cable.
I hope this helps.
CIndy Wells
Oct 21, 2011 | LG W2343T-PF Monitor
How to huck up tv to desk top computer
Depending on the computer, you can use the VGA port or the HDMI1 port and the PC audio in (above the digital audio out) with the appropriate cables. The audio cable is a 3.5 mm audio patch cable. Use standard VGA or HDMI cables.
Then press the input button to select either the PC (VGA) or the HDMI1 port as needed.
Then make sure the computer is sending a signal to the desired port. (You may need to enable the port in the BIOS.) Make sure the monitor is on when you start the computer. With Windows, you can usually select the desired monitor by right clicking on the desktop and then choosing the display options. (for Win7, see Screen Resolution then detect the monitor.)
I hope this helps.
Jan 16, 2011 | Toshiba 40G300U TV
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
May 12, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
I don't have audio on my Envision monitor
If you don't hear audio from your monitor, you should should check the audio connector if it is properly inserted or not to your monitor audio in port and on your computer audio out port. This port is usually color coded with green color and same with the connector jack.
Consider also checking the sound volume of your monitor and computer.
Hope this could help..
Don't forget to rate. Thanks..
Mar 24, 2010 | Computers & Internet
WHERE DO I HOOK UP A HEADSET AND MIC AT ON THIS MONITOR?
Your monitor may not have an audio connection built in.
You'll have to use the speaker and mic jacks on the computer if there are none on the monitor.
Mar 12, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
I can't get any sound from the monitor
Need to plug an audio cable from the Vision Monitor (Audio IN port) to the Lenovo 3000 (Audio OUT port)
Jan 11, 2009 | TDV Vison vi06fv19x Monitor
No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
576 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
