I believe Vizualogic has serious quality problems. I had RT20 installed and it was defective to start with. The headphones did not work on one unit and the other unit made a loud sound when it was turned on. I had the units replaced. The new units had a new problem - Disc Error. The players were not able to read the discs. The installer tried another unit and it also had the same disc error problem. Interestingly, the word disc was spelled as DSIC - can you believe the quality control on Vizualogic prodict?
The installer then found that a wire had come loose in one of the units. He applied some tape to hold the wire in place. The unit seemed to transmit sound again. Well, a broken connection, disc error in multiple units and incorrect spelling was enough to turn me off. I am now trying to get some other brand installed.
Do the headrests detach?? If they do, you can buy the pair of 7" headrest DVD/Monitors all-in-one from Farenheight (made by Jensen). I have used these several times. Not only do the headrests match,but the product lasts too! The best part is that they are about 1/2 the price of many others.
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
Try checking the line in from the video distribution block. A black cable under the seat that is probably zip tied to the frame. There should be a point in the cable that is a plug(maybe wrapped in protective foam tape) just unplug and replug the cable.
