Question about Flat Panel Televisions
Substitute flyback transformer 257805 causing skewed picture on flat screen
I have a rca 32f530t 32 inch truflat television replaced the nla flyback transformer drawing # pn 1585163D with replacement transformer 257805. now the picture has an hour glass apperance sides of the picture curve inward like it is trying to pull the picture for a non flat screen. any solution?
Re: substitute flyback transformer 257805 causing skewed...
You have a pin cushion problem Checking the resistance to ground at DL04(K) found it was 8 ohms. Disconnecting the Pin modulator board at connector HL83 cleared the 8 ohms indicating the 8 ohms was caused by the Pin modulator board. Closer observation a capacitor CL85 a 6.8 mfd electrolytic, finds it to be vented and it was causing the 8 ohm short. Replacing HL85 pn 238292. This corrected the symptom.
Posted on Dec 18, 2007
Thanks for the help, I was looking for an idea on where to find the proper replacement part but all I found was a smart a**
Posted on Nov 29, 2007
Call a qualified technician. Obviously you dont have the training necessary to repair televisions.
Posted on Nov 28, 2007
0 characters
3 Points
Rca 32" lcd tv.vertical lines on entire screen,no pix.
? 5:29 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
I have sound but no picture on my tv sharp aquos 20 inch
if you mean have sound but no Pic.or no raster, horizontal section is the culprit. most problem is at the Horizontal output section that drives the Flyback transformer. Pull out that HV cap & test them to ground if there is some arc coming out. No arc means failed output section or the flyback transformer need to be replace..
Sep 25, 2013 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
There is a four inch black line on one side of the screen
I think your problem maybe picture tube.
next try
At first test for you flyback transformer and A.C. transformer out put voltage.
Best get it checked at your local repair shop.
Send report
Jul 27, 2011 | Zenith Z42PX2D Television
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Flat Panel Televisions
Vertical lines in the picture
Hello, This require you opening the television and having an ohmmeter to work with. This is a vertical deflection problem - possibly a bad capacitor, bad connection, flyback/pumpup diode, or other component.
If the symptoms change - particularly if they become less severe - as the set warms up, a dried up electrolytic capacitor is most likely. If they get worse, it could be a bad semiconductor. Freeze spray or a heat gun may be useful in identifying the defective component.
It is often easiest to substitute a good capacitor for each electrolytic in the vertical output circuit. Look for bad connections (particularly to the deflection yoke), then consider replacing the vertical output IC or transistor(s).
A defective deflection yoke is also possible or in rare cases, a bad yoke damping resistor (e.g., 500 ohms, may be mounted on the yoke assembly itself).
Where there is a wide running vertically on the screen the likely causes could be a missing power supply voltage, defective vertical output IC, or a component associated with it is likely bad. A bad connection or blown fusable resistor may be the cause of a missing power supply voltage.
The following are NOT possible: CRT, flyback (except possibly where it's the source for a missing voltage but this is more likely just a bad solder connection at a flyback pin), tuner (except for the famous RCA/GE/Proscan or Sony models where the controller is at fault - see the sections on these specific brands). I am just trying to think of really expensive parts that cannot possibly be at fault :-).
Note that some movies or laser karaoke discs are recorded in 'letterbox' format which at first glance looks like a squashed vertical problem. However, the picture aspect ratio will be correct and turning up the brightness will reveal a perfectly normal raster above and below the picture.
May 20, 2010 | LG 32LG40 32 in. LCD HDTV
No picture on tv
probably the Flyback is damaged is the high voltage transformer inside of the tv so you you need to take it to repair.
Nov 09, 2009 | Flat Panel Televisions
My hdtv picture is shrinking
flyback transformer or the equivalent IC needs to be changed ( some brands use and IC rather than a transformer)
Sep 22, 2009 | Flat Panel Televisions
Blue stripe down center of screen
Is this a tube television? If so, sounds like the flyback transformer is dead. Take it to the service depot FOR AN ESTIMATE!!!! It's probably cheaper to buy a new TV then repair the transformer.
Jan 01, 2009 | Insignia IS-LCDTV32 32 in. Television
RCA 32F530T
No you can get a replacement from Suburban Electronics
Give the model number or if you can fine the CTC # they can get you a sub for around $18.00 plus SH
Jul 23, 2008 | RCA Flat Panel Televisions
Flat Panel Televisions Logo
399 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
