Question about Denon AVR588 Receiver
Denon AVR-2309C1 will not play sound through
We recently installed a home theatre unit with all componets feeding through our Denon AVR-2309C1 amplifier. All sound was working earlier in the day but suddenly without warning no sound will play through our main zone. We have a Zone 2 set to a Cd player and it works fine and no matter what we try (playing the working cd player through main Zone, or playing tv/dvd through) it will not play sound again. When we switch from Zone 2 to Main Zone we can hear the amplifier click as if it is switching zones. We noticed at times the amplifier will simply switch itself off. these are all brand new componets and a brand new amp. please help this is extreamly frustrating
    President:
  • Denon Master
  • 1,114 Answers
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Posted on Jul 01, 2009
Audio very muffled.
Your Denon AVR output is being clipped severely because of improper Speaker impedance or wrong interconnection of inputs check that out why don't play the Tuner and notice
Jun 24, 2015 | Denon Avr-2308ci Home Theatre Receiver...
No sound from Denon AVR 988
make sure the TV audio setting is set to send sound through to the Denon not just out of the TV speakers, you wont be able to do both
Mar 17, 2014 | Denon AVR-988 7.1-Channel Multizone Home...
Same problem as below, I have the Denon AVR 790 and the sound keeps switching to headphones. Blowing into the socket did not help. Both unpluging the AV and putting the headphones in and out fix's the...
The unit thinks there are headphone plugged in even when there are not. You need to have the headphone jack replaced. This is a common problem with this model. Another way to fix it if you don't plan on using the headphone jack is to unplug the cable going to the headphone jack board. This will disable the headphone jack, and stop it from sending an erroneous signal to the micro.
Jan 31, 2014 | Denon Avr-790 - 7.1 Channel Home Theatre...
Want to put set of outside polk speakers to Denon avr 2807
Do you have outputs for both A and B speakers? If so you can easily hook the outside speakers to the B outputs.
Jun 16, 2009 | Denon AVR-2807 Receiver
Connecting a sony blu ray 350 to denon 1601/ home theatre
Yes select audio optical out on your Blu Ray Player under Audio settings and make sure the Denon is set to Optical or Auto in. You should be set to go
Sep 27, 2008 | Denon AVR-1601 Receiver
Is-lcdtv32 and Home Theatre
run all of your components through the stereo first and just bring the video out of the home theater
thanks
scott
May 29, 2008 | Insignia IS-LCDTV32 32 in. Television
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
Losing treble at higher volume
There are two things. First check the sound settings of the DVD player. It might be putting out a lower quality sound on the CD side of things.
Secondly try to determine if the speaker tweeters are working. Connect the speakers if you can to another sound source. If the speakers are good and the settings fine. Then you have a fault in the amp unit.
May 26, 2017 | AAD C-600i Main / Stereo Speaker
Denon AVR588 Receiver Logo
399 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
