ICONS ARE INVERTED AND THE SCREEN FLASH ININTEROMPLY
Proscan Tablet
well its sounds like the problem starts from when you downloaded the stock firmware and it basically affecting the touch sensivity of the tablet ,and you send when you flashed it still the touch remain the same meaning it didnt work fully .so maybe you need to flash it again and restore factory settings
Jul 02, 2013 | Computers & Internet
Tip
Black and white or negative screen resolution in Mac OS X
A black and white display, or negative screen resolution, is an issue which can occur within the various Mac OS X system versions ranging from Mac OS X 10.3 to Mac OS X 10.6.
It can appear as an anomaly which can leave a Mac User dumbfounded, not sure what is going on.
At one time your screen is normal like this, but then somehow,
the screen changes into this strange negative, inverted screen.
So how does this occur?
The answer is more simple than you think.
An inverted screen like the one you see in the screen shot above, is not actually an anomaly, or the result of some sudden strange happenstance. What's more, chances are, this occurred because of what you did.
Its an easy fix however, because the only way your Mac OS X desktop screen can turn into a negative or black and white resolution, from its normal color resolution, is if a setting within your Mac OS X system has been modified.
To return your screen back to the normal color resolution, follow these steps:
* Click on the Apple menu icon, located on the upper left corner of your Mac OS X desktop screen.
* From the drop down menu, select System Preferences.
* Within System Preferences, select the pane (in System Preferences, Apple references all icons as "panes") entitled "Universal Access".
Quick Note About Universal Access:
The reason this System Preferences pane is known as"Universal Access", is due to the purposes Apple designed it for. If you notice the image for this pane above, this symbol for this feature, is similar to a placard or sign you would see on a car license plate, parking space, door or building, for an individual who has a disability or is handicapped.
Universal Access was designed to enhance features like Voice-over speech (your Mac talks to you), screen size, display settings, keyboard and mouse settings for those Mac users who are vision impaired, hearing impaired and /or physically disabled.
* For the next steps in the process:
Click on the Universal Access pane.
If you look in the screen shot, under Display, you will see that the current setting is "White on Black".
Click on the radio button entitled "Black on White"
and this is the window you will see:
Back to normal!
That is all it takes, to return your desktop screen resolution back to normal.
This is why you were suggested as the probable cause" for your desktop screen to go into Inverted mode. Chances are you may have been in System Preferences, clicked on the Universal Access pane, and in exploring settings, may have clicked the Display setting and the
White on Black radio button, causing the screen to go into
the inverted mode or change in gray scale.
Another theory could be that you may have accidentally pressed the Ctrl-Alt-Apple Command keys on your keyboard, combined with either < > keys, depending on if you were in process of' increasing or decreasing contrast on your Mac's screen or display.
The true purpose of the inverted screen mode or change in gray scale, is to aid Mac Users who may be sensitive to the bright normal colors, that you and I see on the standard Mac OS X display screen, due to poor or failing vision.
So now that your screen is back to normal, if you should see an inverted display, or screen that resembles a negative resolution, like that of a photo negative, you know how to correct this issue.
For more information on Universal Access, click here.
Regards,
- Mactechtrainer
on Feb 08, 2010 | Computers & Internet
Why is everything i look at inverted?
If everything is inverted, you may have the display orientation set for Landscape/Portrait (flipped). In this case, the taskbar will be at the top of the screen. With most Windows OS versions, click on the desktop (anywhere with no icons or running programs) and select Screen Resolution. In the drop down menu for Orientation, change the setting. (Landscape is usually the desired choice for computers with Widescreen displays.)
With some laptops, you may find this under Display Properties or Graphics Options. (On my desktop, changing the Graphics Option is available but doesn't work.)
I hope this helps.
Sep 15, 2012 | Computers & Internet
My Laptop Backlight switches off, after windows start-up..I need to get this fix or advice will do..
If you can barely see the icons when you use a flash light to shine on the screen, then you lcd inverter is bad. Replace the lcd inverter and your screen will be ok.
May 22, 2012 | Dell Latitude E5400 Laptop
My iphone suddenly changed colors. The pictures all look like b/w negatives. The icons are really weird colors. Help. Thank you.
Hello Michel,
In the iphone 3GS there is hidden feature called the "White on Black". It completely inverts the color scheme of your iPhone. The background on the home screen will be white, and the text will be black.All of your native apps will have an inverted color scheme. to disable this feature, Go to Settings then General then Accessibility then Turn of White on Black.wirelessage.jpg
May 19, 2011 | Apple iPhone 3G
Inverted image
no solution I know and I have the same problem!!! Did you find a solution yet???
Mar 04, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Laptop not showing desktop just remains blank when switched on
hi mikkk,
try the following.
1. right click on your desktop (blank screen ). go to arrange icons by--> check show desktop icons. this might fix the issue.
2. or in the task manager. go to file--> new task....Run "explorer.exe" ( type it without the inverted comas). this wud fix the issue.
hope to get rated as helpful.
regards.
bzoy
Jan 03, 2008 | Acer Aspire One PC Notebook
Inverted image problem
Has this just happened or has it always been like this? There appears to be a a fault in the main board and only replacement will cure- So may be if the camera is more than a year or so old- time for a new one. Meanwhile do speak to the Canon Tech Support on the Web site. And whilst the matter is still not resolved ,shoot holding the camera upside down- seriously - tell me what happens.
May 19, 2007 | Canon PowerShot A85 Digital Camera
Computers & Internet Logo
David Payne
David Payne
