I do i stop the indesit widl 126 mid cycle?
How do i stop the indesit widl 126 mid cycle?
  • 15,935 Answers
Open the door - or press stop/cancel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: indesit widl 126 stopped mid
Sounds like your transmition is bad on the washing machine. Replace the transmition. You will need to call a repair man out to fix
Posted on Dec 09, 2010
I have a silver Inesit WIDL 126 S washer dryer. Whenever the wash cycle completes, it then lets in some water from the inlet. Then stops. I tried draining it, it drains, then lets in water from the inlet,...
A device called a solenoid open and closes when activated by the control board (circuit controller). If debris collects inside of the chamber when it is open or closing, it can leak or simply shut down. This device will open upon command and allow water to enter or exit. It takes its orders from the command center and if it is damaged, plugged, or no longer capable of switiching on and off, it needs replacement.
Mar 12, 2014 | Indesit W 123 Front Load Washer
Indesit 1200 widl 126 no lights showing when machine switched on. Checked plug fuse is good
Hi Whalley
Are all fuses ok? kindly check your outlet as your power source and measure the voltage.
Jan 19, 2014 | Car Audio & Video
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit WIDL 126 washer/dryer
look at http://www.indesit.co.uk/indesit/productsheet.do?productId=30538UK
Jul 06, 2008 | Computers & Internet
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Washing machine filling with water when switched off
Electric inlet valve doesn't close properly. You should get it replaced ASAP. It is a cheap part and quite easily replaceable. Turn off water to your machine until you fix this and keep it unplugged.
Apr 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
470 people viewed this question
Top Washing Machines Experts
