Question about Electrolux Dishwashers
Main motor burn
Main motor of dishwasher burn?
  • Electrolux Master
  • 19,396 Answers
Inspect wiring harness from control board to pump. Test and eventually replace the impeller pump.
You can find parts and diagrams for your appliance here.
Posted on Jun 28, 2009
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Need Owners Manual to see Wiring Installation/Pump Burned Out/Motor possibly burned out
Asko built d/w which is now owned by sub zero wolf. Fyi . To get parts you could call mfr direct which is cost effective. Hope this helps
Jul 22, 2012 | Viking 24 in. Professional Series VUD141...
It is not cutting
Dear Sir:
Please see this possibilities:
Power from the house
test the blown fuse or c. breaker from your house
Door switch
test the switch for to starting relais and turn ON the main motor see the diagram
Wiring
test any wires for loose, burn, or break and repair
Timer or selector switch
test for defective, clean contact, repair any wires loose, burn, or break, see the diagrams
GOD BLESS YOU
5_13_2012_2_57_02_pm.gif5_13_2012_2_57_25_pm.gif5_13_2012_2_57_42_pm.gif5_13_2012_2_57_58_pm.gif5_13_2012_2_58_09_pm.gif
May 13, 2012 | Dishwashers
My LG dishwasher LD-2040WH washed and as soon as the element goes on it switches off by itself. I put it on the gentle cycle and then it switch off and now there is nothing going on it is completely dead...
see the w. diagram for test
1) Test the switch door for defective, this switch can be open or defective and can be open the starting relais and turning off the main motor.
2) Timer: test for defective, clean contact, repair wires loose, broken, or burn.
May 09, 2012 | Whirlpool 24 in. DU940QWD Built-in...
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Mar 26, 2011 | Frigidaire Professional Series 24 in....
I got a double drawer fisher and paykel dishwasher and the first drawer was not working and after a few days we saw that it was smoking and smells burn so we turn off the main switch and took out the...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hello I have a hotpoint aquarious dishwasher and its making a burning smell and tripping the fuse box do you know what this could be?
Almost certainly the main wash motor or the capacitor is faulty.If not look for the line filter module. If that is blown it will also do that.Rewire without it.(your mail power cord is connected to it as it enters the machine on the inside..
May 27, 2010 | Dishwashers
Hi, my Hotpoint aquarius SDW60 has blown my main fuse, and is overheating giving a burning smell, 2x lights flashing on the front?
There is probably a short circuit on the appliance, or a component such as the motor or timer/control board is defective. Contact an appliance service company.
Feb 22, 2010 | Hotpoint Dishwashers
Dishwasher not working
The motor may be burned out or there may be another electrical issue which would also cause the symptoms you describe. Call around and try to get an estimate, and at the same time look at new ones on sale.............one question is how secure will u feel with that maching......now that it has acted up like this.
Sep 07, 2009 | Dishwashers
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
